torque converter swap help..all apart and confused
#1075200
11/16/14 01:33 AM
Hey guys I have my 89 mighty max 4 cyl auto all apart and have a v6 converter I was going to swap on as I read herr several times that it's a direct swap but both transmission input shafts look very different.. any advice..both are non lock up
1989 Mighty Max 4WD 2.6 Turbo,Auto EFI...megasquirt! 4.62 Rear LSD! 1989 Mighty Max 2WD 2.6 5 speed slammed 1993 Eagle Talon TSI
Re: torque converter swap help..all apart and confused
[Re: boostin]
#1075201
11/16/14 06:46 PM
mmmm I think you have to use the V6 auto....
1997 Montero LS with a motor swap a 1990 V6 12valve ported heads full 2.5in Ex I run stock tire size for Daily use, off road have 33x12.5 working on going trubo.
[Re: TainterRacing]
#1075202
11/17/14 02:54 AM
Well I think I got it. I changed the oil pump and front shaft...I was concerned of the condition if the v6 mystery trans. All together now and works great huge improvement with the turbo!
PHP: 7.4.33 Page Time: 1.117s Queries: 15 (0.003s) Memory: 0.5924 MB (Peak: 0.6456 MB) Data Comp: Off Server Time: 2026-06-10 02:56:21 UTCValid HTML 5 and Valid CSS
