Re: Gen 1 3.0 engine upgrades [Re: Lloyd Swartz] #1075335 12/03/14 02:39 AM
Gearing is prolly best bang for the buck. D300 with crawler gears would be huge offRoad
Re: Gen 1 3.0 engine upgrades [Re: ryany] #1075336 12/03/14 05:32 AM
bodyswapped8789 Offline OP
Heads are the most restricted area on most engine's, cam's can be good for both torque and HP depending on the design. Bigger TB's can be found on I think the 3.3 Chrysler diaper wagons and a couple other models (Raider TB is smaller then 52mm I think?) Their are a few 3.0 plenums that could potentially work on the raiders 3.0 but I think the 89 is the least restrictive from what I gather. other then DOHC models. Intake is a waist of time for a few reasons,
1.There is alot of design that goes into an OE intake system by guys far smarter and better paid then me.
2. all "cold air intake systems are actually "hot air systems" unless it routes to the exterior of the engine bay,(like most OE air boxes)
3. May as well be called a straw for wheelers.
4. This is the most important IT'S NOT A HONDA!
Any way enough on that, I was just wanting to build a bit more power now that its my only driver other then my Harley, and was wanting to do a few things I can tackle on a weekend. Just wanted to see if anybody has built power with yard parts.
Gearing I agree is probably that way to go, and I am looking for the GEN 2 rear axle at the yards actively. From what I remember GEN 2 axles can be found with lower gears then the GEN 1 M/T 3.0 rear end, Am I right? check the tag on the fire wall, Correct? plus locker,brakes ect, ect. that way I don't have to worry about over rev on the highway.
Once I finally get a new truck it will be full on rig.
and it wont matter. Oh one more thing and maybe I should start a new thread, but has anyone converted crank windows, to power? Got a pretty complete 84 monte at the yard with PWR windows. Got spoiled with my other car! <img src="/forums/images/graemlins/lol.gif" alt="" />
89 V6 manual trans Dodge Raider frame 87 cold weather pkg 2" body lift, Soft 8's wraped in BFG km2 33x10.5x15, JDM Pajero yellow Bosch fogs. Yackama basket. Duel bouncies gen II rear springs,gen II ft brakes,master and booster.
Re: Gen 1 3.0 engine upgrades [Re: bodyswapped8789] #1075337 12/03/14 08:19 PM
KrzyDav Offline
T.B. from 3.0 M.Sport is like 80mm. 2different TBs are used and 2 different ICS. Vacuum damper for EGR is in the vacuum hose and not in casting as in '89. I was going to do this because my '89 water heated air controll went bad. I modified it to get by.
Some 92 SRs came with 4.88 and airlocker. The problem is they have high pinion front diff.
IMHO your looking for slight (if any) improvement, and gonna get headaches and waiste $.
dave h.
Re: Gen 1 3.0 engine upgrades [Re: KrzyDav] #1075338 12/04/14 02:29 AM
You saying the rear axle swap or the T.B is a waist?
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.6091 MB (Peak: 0.6672 MB) Data Comp: Off Server Time: 2026-06-07 05:59:34 UTC
