Page 2 of 4 1 2 3 4
Re: Gen1 2.6L to 2.4L swap question [Re: 87monty] #1075464 12/10/14 05:36 AM
I've got both swaps, in my driveway. Neither one runs, but that's my problem.
Re: Gen1 2.6L to 2.4L swap question [Re: JohnnyBfromPeoria] #1075465 12/11/14 02:15 AM
Malykaii Offline
Check out projectzerog.com for a lot of info and a complete list of where to find a 4g63/4 wide block.
88 Montero, StarQuest turbo, Kormex 5speed +tuff-pan w/phoenix f. stage2 clutch, 4in lift+33' tires, 4.875 lsd, short-throw shifter, Aisin hubs, SR big brakes, gen2 uca's, elantra alt, and so much more... 16g turbo w/hardpipes + 4.90 locking disk-brake axle soon (maybe lsd or aussie front??)
Re: Gen1 2.6L to 2.4L swap question [Re: Malykaii] #1075466 12/15/14 09:13 PM
zarktheshark Offline OP
I have been reading that site and others but can't seem to find the info I'm looking for. I'm trying to find a good balance between HP and MPG. Since I drive over 50miles per day for work, I need to get the MPG, but I also struggle on the hills with the 2.6 setup, so I'm wanting more power. If I look at taking a straight up 2.4L swap, do people notice a decent difference? I found a MS 2.4L, but that is the 7bolt. I think I understand that I would also need the flex plate, but what about the torque converter? will it bolt up to my AT? In my mind, I think I'm looking for something in the 150hp range, but I just don't know. I know turbo would be fun, but not sure if I need it. I'm just looking for the most cost effective swap that is not a 2.6L
'88 Raider. 2.6L dead...2.4L swap in progress, AT, 33's, 2 bouncy seat,AC, CC, 2.25 exh, 2" Tbar, 2" BL, rear DB, rear LSD,4.90's, SW hubs,gen2 uca's, KYB shocks, snorkel, elec fan, MSD.
'99 chev k3500 crewcab
'15 Subaru XV
'03 BMW i325
Re: Gen1 2.6L to 2.4L swap question [Re: zarktheshark] #1075467 12/15/14 09:38 PM
and I'm still trying to understand the JDM thing. I see a JDM MS 2.4L but don't know if I should even consider it unless I get the matching harness and computer. thoughts?
'15 Subaru XV
'03 BMW i325
Re: Gen1 2.6L to 2.4L swap question [Re: zarktheshark] #1075468 12/16/14 12:39 AM
Get the Sport 2.4 with wiring and flexplate/spacers, from there it bolts like any 2.6.
If you need the flexplate and spacers order them for a Pajero 2.4 7 bolt
Re: Gen1 2.6L to 2.4L swap question [Re: TOASTY] #1075469 12/16/14 05:17 AM
Ok. For the spacers, what are they for? what are they spacing out? Also, for the exhaust, will my manifold bolt up or do I need to get that too? are there any other accessories I should pull from the MS vs using the one from the Raider? Thanks
'15 Subaru XV
'03 BMW i325
Re: Gen1 2.6L to 2.4L swap question [Re: zarktheshark] #1075470 12/16/14 06:29 AM
I
IncorpoRatedX Offline
The spacer goes between the flywheel and the crank, it spaces the flywheel out to where it properly sits, see the manufacture of the transmissions was not the same manufacture as the engines, since the trans was used in many things, it was up to the engine to 'properly align itself' so thus came shims, spacers, bushings, etc etc.
There's a 1/2" thick spacer between the crank and the flywheel, then a large flat washer with 6 or 7 bolt holes in it, this gets stuff aligned.
exhaust manifolds are different i think, i would just yank the whole engine, engine harness and ECU.
V45W - 1999, 3.5 sohc, winter package
L042G- 1987, 2.6 carb, auto - Cylon Raider
A112 - 1973 Galant Wagon - 4G63 Turbo, 5 speed
L023G - 1983, 2.6 carb, 5 speed manual 4WD
L028 - 1983, 4D55 turbo diesel 2WD
Re: Gen1 2.6L to 2.4L swap question [Re: IncorpoRatedX] #1075471 12/18/14 06:17 AM
From what I can tell, the MS with 2.4L only came in a Manual Trans. So it looks like I will have to purchase the Flex Plate and spacer for the Pajero. Where did you get them from? doing a search for the MB numbers, I don't see any pics. can I assume that MB936621 is the flexplate?
and MB936623 is the spacer. Do I need the adapter as well(MB936624)? I found the above numbers on Discount Mitsu Parts.com
Also, the leads I thought I had on a MS engine were false advertising. There is a JDM version shipping over, but it wont be here until mid January and they want $1100 (no harness). On car-part, I see some are available, but they are over 500 miles away, so I would have to figure out shipping. with shipping, I'm guessing it would also be close to $1100. Is the JDM worth waiting for? Any downside to them? Thanks for the help.
'15 Subaru XV
'03 BMW i325
Re: Gen1 2.6L to 2.4L swap question [Re: zarktheshark] #1075472 12/18/14 07:15 AM
Kevin C Offline
http://portland.craigslist.org/grg/pts/4804517444.html <img src="/forums/images/graemlins/zombie.gif" alt="" /> <img src="/forums/images/graemlins/ignore.gif" alt="" />
Re: Gen1 2.6L to 2.4L swap question [Re: zarktheshark] #1075473 12/18/14 07:44 AM
haztoys Offline
Beware of JDM motors ... As one who has dealed with them ...Subaru and Mitsu more often then not all the parts parts on the out side of the motor are not the same as USDM motors ... Is what you get is a long block with a mess of parts you cant use... Great for someone that is replacing a motor on there reg ... Not good for someone doing a swap ... Not saying a MS 2.4 JDM is that way ..I have no clue never dealed with 'that' motor ... Do your home work .. At $1100 out west here Montys of all Gen's are every where and for a 1K more you could drive one home and get a big chunk of cash back on the parts left over ...
Has anyone ever got someone from car-parts.com to ever email back on a part ..I never have ... <img src="/forums/images/graemlins/confused.gif" alt="" />...
Page 2 of 4 1 2 3 4
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.6499 MB (Peak: 0.7560 MB) Data Comp: Off Server Time: 2026-06-21 12:18:21 UTC
