OBD2 code scanner recommendations? #1075927 12/30/14 05:53 AM
DVoeks Offline OP
So my check engine light came on today. I don't even have a manual for this thing yet but I found some shop manuals on Amazon and was looking at their code scanners. Does anyone have a scanner they can recommend? It doesn't have to be fancy. I just want to be able to read the codes and clear them. I have a 97' SR. Thanks.
Dwight
97' Montero SR
99' F250 SCLB 7.3
Re: OBD2 code scanner recommendations? [Re: DVoeks] #1075928 12/30/14 06:17 AM
danz91crx Offline
Factory service manual can be found at mitsubishilinks.com
I have a cheap obdII scanner I got from ebay its a U581 Haven't used it a lot but seems to do what I need when needed. Tells what a code is rather then just the P0... has live data and freeze frame functions as well.
1990 LWB RS A/T
1990 LWB Base A/T
1991 LWB LS A/T Going...Going...
Re: OBD2 code scanner recommendations? [Re: DVoeks] #1075929 12/30/14 06:25 AM
zarktheshark Offline
I'm pretty sure Napa in town will check it for free. As for manuals, you should check out mitsubishilinks.com. Most of the FSM's are up there.
'88 Raider. 2.6L dead...2.4L swap in progress, AT, 33's, 2 bouncy seat,AC, CC, 2.25 exh, 2" Tbar, 2" BL, rear DB, rear LSD,4.90's, SW hubs,gen2 uca's, KYB shocks, snorkel, elec fan, MSD.
'99 chev k3500 crewcab
'15 Subaru XV
'03 BMW i325
Re: OBD2 code scanner recommendations? [Re: zarktheshark] #1075930 12/30/14 10:15 AM
DVoeks Offline OP
I will check out mitsubishilinks but as far a NAPA is concerned, as much as I like them, I would rather read the code in my driveway or wherever I notice the light come on but that is a great idea for the time being. By the way, how on earth do I turn on the high beams on this thing? The switch is not on the headlight stock. Thanks again.
97' Montero SR
99' F250 SCLB 7.3
Re: OBD2 code scanner recommendations? [Re: DVoeks] #1075931 12/30/14 01:25 PM
On my '95 SR you pull the stalk toward you to toggle between high and low beams.
Re: OBD2 code scanner recommendations? [Re: DVoeks] #1075932 12/30/14 04:55 PM
plh Offline
I use a bluetooth code reader that I picked up off Amazon for like $20. Interface with an android devise (my phone or tablet) with the App: Torque. Reads and clears.
  • '83 Might Max: IG @83mmax
  • '88 Raider: my OG
  • '89 Raider: rescued
  • '92 RS M/T: sold
  • '93 SR: sent to crusher
  • '05 Montero LTD: sold
  • '18 PHEV: wife's daily
  • '14 OL GT
  • http://www.tuffpans.com
Re: OBD2 code scanner recommendations? [Re: JohnnyBfromPeoria] #1075933 12/30/14 06:41 PM
DVoeks Offline OP
I can make them toggle but the highs won't stay on. Normally you push the stock forward and you get high beams. What do you do to keep your high beams on? Thanks.
Dwight
97' Montero SR
99' F250 SCLB 7.3
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.005s) Memory: 0.6188 MB (Peak: 0.6932 MB) Data Comp: Off Server Time: 2026-06-07 01:19:33 UTC
