Help with installing snorkel #1076003 01/03/15 04:10 AM
j4tk1 Offline OP
I need some help with installing a snorkel on my 1997 Montero. I bought the one from Ebay that doesn't come with any hardware. I was wondering if anyone could help me out on what to buy and maybe provide some general instructions on what I should do and how to start.
I checked the post by off-roader, but all the pictures have expired and I cannot see what I need to do.
Thanks in advanced.
Re: Help with installing snorkel [Re: j4tk1] #1076004 01/03/15 07:39 PM
Does it at least come with a mounting template?
Which one did u buy? An actual safari snorkel or a clone?
As for hardware, be sure you buy stainless steel or it will rust out.
You'll also need a hole saw.
Re: Help with installing snorkel [Re: off-roader] #1076005 01/03/15 09:32 PM
j4tk1 Offline OP
I bought the one from Rexypow.
And I have seen your post, but I am more of a visual learner and I think the pics have expired from there.
Mr.Lingley
Re: Help with installing snorkel [Re: j4tk1] #1076006 01/04/15 09:00 PM
I'm a visual learner too, but I can't find those old pics rt now. I can tell you the install is straight forward for the most part.
The template is pretty much spot on.
You'll need to fabricate tubing from the snorkel (round opening) to the intake hose (oval opening). I used a piece of plastic rain gutter fitting to do this along with lots of tape. I'm not sure what the tape was but it's available from home depot. IIRC, it was aluminum on one side. Thick black adhesive on the other side. Grasscat knows for sure.
Again, use stainless steel hardware to mount it or you'll be sorry.
Ask any questions and I'll do my best to answer them. Oh and I do have the rig so I can go out to take some "after" pics if it helps.
HTH.
Re: Help with installing snorkel [Re: off-roader] #1076007 01/04/15 09:33 PM
j4tk1 Offline OP
My main concern is the mounting. Should I just buy some bolts with some nut locks and some washers?
So basically I'm just going to be cutting a big hole, running a hose form the snorkel to the air intake, seal all possible places air could come through, and then mount the snorkel onto the vehicle?
Mr.Lingley
Re: Help with installing snorkel [Re: j4tk1] #1076008 01/04/15 09:44 PM
danz91crx Offline
Have you tried looking on youtube for ideas?
1990 LWB RS A/T
1990 LWB Base A/T
1991 LWB LS A/T Going...Going...
Re: Help with installing snorkel [Re: danz91crx] #1076009 01/04/15 09:52 PM
j4tk1 Offline OP
Yes, I have. They are all mostly installation of complete kits. Whereas the one I bought comes only with A-frame mounting hardware. But it seems simple enough.
Mr.Lingley
Re: Help with installing snorkel [Re: j4tk1] #1076010 01/05/15 05:18 AM
IIRC, for the bracket on the A-pillar we used stainless steel rivets and marine grade epoxy (or it might have been rtv). For the fender mounts we removed the inner fender and bolted the Snorkel in place.
Also iirc we may have given copies of the installation pics to rexypow.
HTH.
Re: Help with installing snorkel [Re: off-roader] #1076011 01/05/15 05:52 PM
j4tk1 Offline OP
Yeah. This helps me out a lot. I understand a lot better. Was making it more complicated than it is.
I appreciate the help.
Mr.Lingley
Re: Help with installing snorkel [Re: off-roader] #1076012 01/06/15 02:57 AM
j4tk1 Offline OP
[/quote] We used stainless steel rivets and marine grade epoxy (or it might have been rtv). For the fender mounts we removed the inner fender and bolted the Snorkel in place.
HTH. [/quote]
What size rivets and bolts did you use?
Mr.Lingley
PHP: 7.4.33 Page Time: 0.010s Queries: 16 (0.007s) Memory: 0.6373 MB (Peak: 0.7613 MB) Data Comp: Off Server Time: 2026-11-02 23:30:30 UTC
