Re: 3.0 V6 SOHC head info [Re: haztoys] #1076044 01/07/15 09:49 AM
KrzyDav Offline
my 2 cents on original question.
In 1992 heads started coming from factory with the snap rings on the exhaust guides. '91 and previous had a TSB that describes cutting tool and snap ring installation. If heads have ever been redone, they will most likely have the snap rings on the aftermarket exhaust guides.
The Steath/Diamante had different cams. Some cams have marks on them,, but the marks change location with each production run on these so I wouldn't trust ANY markings.
dave h.
Re: 3.0 V6 SOHC head info [Re: KrzyDav] #1076045 01/08/15 03:53 AM
Atta boy, Krz. Good, solid info. I'd forgotten that stuff.
Re: 3.0 V6 SOHC head info [Re: JohnnyBfromPeoria] #1076046 01/08/15 04:45 AM
haztoys Offline OP
Ding Ding .. We have a winner .. Info not rumors ...
Part numbers are coming up real crazy to all the 'Dont do it crowd..' As if one was to order a '89' SWB Raider cam one would not get the same cam as a '90 LWB to all Montys to Steath and so on to '02' cam ...So is a 89 SWB cam is not the same as 90 LWB on up cam ..?????...Numbers say..?
Then theres the Sigma and in JDM none USDM cars cam... <img src="/forums/images/graemlins/zombie.gif" alt="" /> <img src="/forums/images/graemlins/zombie.gif" alt="" />...
So not sure what to think ..? You tell me..?
Please do home work before posting ...
I think taking the insides of a later car and installing into a 'V6 SWB' block is an upgrade.. Do to pistons and cams ...(The Sigma is where the power is .I think... <img src="/forums/images/graemlins/confused.gif" alt="" /> ) .. To bad FrankR is not around he has info on SOHC V6 12v HP ..
No one has 'hard' info on making SOHC V6 12v HP ..I have some from a 'time far far away '
I get strange info and have some old school info too ... Will see where I end up ...
(Disclamer is SWB we are dealing with... not LWB ...)
Re: 3.0 V6 SOHC head info [Re: haztoys] #1076047 03/15/15 03:22 PM
haztoys Offline OP
Good to be home ... I think the places I seem to end up everyones crazy ...
Got the heads off and home ...They look real good ...Car was days from the crusher ...Will see what I end up with on these ...
Re: 3.0 V6 SOHC head info [Re: haztoys] #1076048 03/18/15 04:45 AM
justice Offline
There was a 6G72 engine manual on mitsubishilinks.com at one time that had a breakdown of the cam codes. I dont think the site is up right now though.
Re: 3.0 V6 SOHC head info [Re: justice] #1076049 03/21/15 09:04 AM
haztoys Offline OP
Thanks ..I'll take a look ... Did a little work on numbers and cam and part numbers ... I'm finding a mess of differant cams ... Dont understand where the 'all cams are the same' came from ...? .. <img src="/forums/images/graemlins/confused.gif" alt="" />
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6186 MB (Peak: 0.6896 MB) Data Comp: Off Server Time: 2026-06-20 19:10:30 UTC
