Know where/how to get headlight washer nozzle clips? MB141436
#1076196
01/09/15 12:53 PM
Hello everyone,
I am posting to see if anyone knows where to get these little headlight washer nozzle clips, p/n MB141436. I'm missing mine on my truck so the nozzles are loose. They are the clip that goes just behind the hole in the metal that the nozzle goes through. Apparently, from what I have read, these clips are solely used by Mitsubishi and only on the 1st gen montero/raider. I do know that these are no longer manufactured and/or sold my Mitsu.
Anyone have any extras or got any good ideas on how to make something similar that will work? I'm open to anything at this point.
Thanks guys.
1989 Mitsubishi Montero SWB V6, Aisin manual hubs, gen 2 front brakes/rotors, rear LSD, A44DL lock-up transmission, BFG 33's.
Re: Know where/how to get headlight washer nozzle clips? MB141436
[Re: 90rustymontero]
#1076197
01/09/15 01:44 PM
#1076198
01/09/15 02:35 PM
[Re: BOPOH]
#1076199
01/10/15 01:50 AM
Thanks for the help BOPOH. Unfortunately, those links say part is discontinued.
[Re: JohnnyBfromPeoria]
#1076200
01/10/15 01:53 AM
JohnnyB,
I didnt see that site before so I just tried ordering through it. Hopefully it wasnt one of those times when I get an email in a few days saying "I'm sorry but the part you ordered is discontinued. " hah
Thanks for your help.
#1076201
01/10/15 04:35 AM
True dat. It may be discontinued. I have ordered stuff before and just had my order cancelled due to that situation. Hopefully is isn't the case. If so, someone will find you a couple in a junkyard.
#1076202
01/27/15 10:36 PM
it should not be hard to make some. The challenge is replacement option for the tee-valve. I have been trying to find an inline pressure valve that can work when the valve in the Tee goes bad.
[Re: RECON45]
#1076203
01/28/15 02:20 AM
Here is a picture of that clip from the back. It reminds me of the Gen II retaining clips for the rear brake lines just behind the spindle. ![[Linked Image]](https://lh3.googleusercontent.com/-cXo-LiXUX3s/VMgZr3oshMI/AAAAAAAAGrc/XVOr4dZbAS0/w1278-h723-no/IMAG1665.jpg)
[Re: Jay Ayala]
#1076204
01/28/15 05:27 AM
Recon, it "shouldn't" be hard to make some, as long as one has access to some spring steel, bent just so, with a slot cut into them in the right size. I say just find some in a junk yard. I'll keep my eyes out for them now that I know folks might want some. They are "pocket items," just like dash light bulbs and fuses.
#1076205
01/28/15 09:29 AM
I can grab you some from either an 88 Raider or 90 Montero if you are still looking.
Epxo rig-98 Montero "SR" with ARB front bumper and 33x9.50's
Trail rig-97 ZJ V8 with long arms and 35's, trailer queen
