Re: New Diesel Raider Owner: Couple of Questions
[Re: plh]
#1076530
02/05/15 03:40 PM
Sorry if that was confusing.
Earlier, I posted that at 50mph my tach is reading 3K rpm. According to the chart, with 4.626 gears, I should only be at 2147 RPM. Were there lower gears made than 4.626?
Another thing I just thought about, could it perhaps be the dakota digital tach unit is acting up?
thanks.
[Re: Collinstr]
#1076531
02/05/15 04:23 PM
a couple things to create the in-accuracy. Your tires if sidewalls say 31" x something really are not 31" high. Probably closer to 29.5" or 30". Speedo in truck is not accurate, are you verifying with a GPS? Tach is not accurate. What transmission do you have?
edit: I see way back its a 5 speed - so assume either a KM145 or V5MT1 which 5th gear is not too far different. I'd check the DD tach adapter. Can't get anything lower than 5.29 (~2600 rpm w/ 29" tires @ 50mph KM145) differential gears, so most likely the gages are incorrect.
- '83 Might Max: IG @83mmax
- '88 Raider: my OG
- '89 Raider: rescued
- '92 RS M/T: sold
- '93 SR: sent to crusher
- '05 Montero LTD: sold
- '18 PHEV: wife's daily
- '14 OL GT
- http://www.tuffpans.com
[Re: plh]
#1076532
02/06/15 05:10 PM
It's got 31" BFG A/T's. I GPS'd the speed and you are right, its about 2-3 mph off at 50mph. This still places the RPM's at ~2700 so I'm pretty sure the the DD adapter is off. I'll try to calibrate it this weekend and let you know. I bought the rig with it already set up, so I'm gonna take the easy route and blame the last guy, haha.
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.005s) Memory: 0.5991 MB (Peak: 0.6527 MB) Data Comp: Off Server Time: 2026-07-09 17:35:52 UTCValid HTML 5 and Valid CSS
