Re: CV Axles Binding and a Diff Drop?
[Re: Malykaii]
#1076597
02/17/15 06:14 AM
While I would think swapping 4.875 in the front AND rear would seam obvious, I agree it's the internet filled with idiots, so got to cover all bases.
I doubt its the lack of transfer case diff as I've had this car for 8 years and it didn't do this for quite a big portion of that.
I a while back had it parked for 6months. Then I regained interest and did a ton of mods, including a torsion crank. Its that first test drive after mods and sitting that it all began. I figured it's the axles, and since I have to change them I might as well 4.875 it, and boom, still same problem.
I'll Jack it up and dig in next week. Lloyds suggestion makes sense... And the reaction you get depends on the surface you're on when you try and turn.
PHP: 7.4.33 Page Time: 0.009s Queries: 15 (0.007s) Memory: 0.5893 MB (Peak: 0.6287 MB) Data Comp: Off Server Time: 2026-07-15 17:29:44 UTCValid HTML 5 and Valid CSS
