Re: #2 has a Bad crankshaft and #1 has a Bad ECU [Re: heathdogg] #1076953 03/05/15 05:11 AM
haztoys Offline
Same crank ..Just harder ...
"Is it good"...
It 'should' be good .. No turning needed I dont keep bad cranks ...( Unless its something bazar..) ...One of the few steamshovel motor parts I still have in my world ..
Numbers are 0.10 on rods and I think stock on mains ... No clue really.. Been some time sents I've dug that deep in the stash..
Re: #2 has a Bad crankshaft and #1 has a Bad ECU [Re: haztoys] #1076954 03/07/15 05:40 PM
heathdogg Offline OP
So I went the u pick it here in flagstaff last to dick around and get a few minor things and found a 90 Montero that wasn't on the list. It hadn't been too molested yet. It had a ecm so I snagged it along with the coil and bracketed stuff. Just plugged it in and it is good. Blacktero lives again!!!!!
Blacktero: 90 Montero Lwb V6 RS Model. 16" Toyota Alloy Rims, Dual Bouncy's; Gen II Front Rotors & Calipers; Rear LSD
Sraider: 87 Raider 2.6 base. Work yet to be done.
Re: #2 has a Bad crankshaft and #1 has a Bad ECU [Re: heathdogg] #1076955 03/07/15 07:01 PM
Good news and good job, Heath.
Re: #2 has a Bad crankshaft and #1 has a Bad ECU [Re: JohnnyBfromPeoria] #1076956 03/07/15 08:26 PM
Jay Ayala Offline
Sweet. Good for you. Another one back on the road.
Re: #2 has a Bad crankshaft and #1 has a Bad ECU [Re: Jay Ayala] #1076957 03/08/15 08:42 AM
Now just need a crank. And since blacktero now moves, time to finish the upgrades.
Re: #2 has a Bad crankshaft and #1 has a Bad ECU [Re: heathdogg] #1076958 03/08/15 07:14 PM
Jay Ayala Offline
Can you remind me why you think you have a bent crank? You realize how much force that takes, right?
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6160 MB (Peak: 0.6851 MB) Data Comp: Off Server Time: 2026-06-20 21:41:12 UTC
