front bearings #1077223 03/14/15 08:57 PM
Nukeiridium Offline OP
Well I changed out my front bearings. Destroyed the brake rotors getting those off , so I did the brake rotors and pads too (rotors had never been done in 140k miles neither had the bearings).
I still don't know if the bearings needed changing, but the front wheels had a lot of play. Not sure if I got the wheel bearing nut on the right tightness. The manual described using tools to measure preload and run out, I screw that.
What procedure do you guys use to get the right tightness?
2002 Sportage 4dr 4x4 soon to undergo an Extreme Makeover!
Re: front bearings [Re: Nukeiridium] #1077224 03/14/15 09:01 PM
Btw the whole reason I went to change the bearings was I was hearing a clicking noise when moving, thought it was front bearing. Turned out it was the rear universal joint but it stopped when I greased the zert. Sigh. Well the bearings were ancient anyway and so were the brakes, so it should save me future work. <img src="/forums/images/graemlins/notooth.gif" alt="" />
I hope that universal joint isn't going bad, I just had the stupid thing replaced like a year ago <img src="/forums/images/graemlins/scared.gif" alt="" />
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.5894 MB (Peak: 0.6375 MB) Data Comp: Off Server Time: 2026-05-30 19:05:16 UTC
