Re: non-stock wheels and fender clearance [Re: rxinhed] #1077342 03/24/15 05:42 PM
F
flyfisher Offline OP
Thanks so much! The thread you referenced is the one I as looking for, but failed to find. I remembered reading it months ago, but could not make the connection. Good information there, as well as good links to other discussions.
BTW, I was really unsure about my wheel width measurement, so I checked out the CORRECT way to measure wheel width and I originally did it wrong. The wheels I want to use are actually 7" wide, not 8". 8" is the OVERALL width, the bead-to-bead width is 7.
I feel a lot better about the wheels and will move ahead with using them. Will send results to the group in case someone else can benefit from it.
Re: non-stock wheels and fender clearance [Re: flyfisher] #1077343 03/25/15 02:55 AM
If you are purchasing aftermarket rims, the 8" width / 4" backspace and 31" all-terrains really increased the handling of my Raider. Once I installed the V6 sway bar in the front, Roxy made a fairly formidable canyon racer.
PHP: 7.4.33 Page Time: 0.011s Queries: 15 (0.009s) Memory: 0.5967 MB (Peak: 0.6456 MB) Data Comp: Off Server Time: 2026-07-16 13:25:59 UTC
