Page 2 of 7 1 2 3 4 5 6 7
Re: Hi it has been a while. Now Head gasket issue 90 LWB [Re: JAVYPRO] #1077366 03/31/15 05:38 PM
Jay Ayala Offline
Javy
Hey I meant to send you a message yesterday but I got so busy in finalizing the work I needed to do to the Raider last night that I was out in the garage until about 10:00pm last night. I sent you the tool and it is Guaranteed Delivery by Thursday. You should be getting it before the weekend kicks off. I lost the receipt with the tracking number or I would provide it. If I find it in the next hour or so I'll send it to you.
Re: Hi it has been a while. Now Head gasket issue 90 LWB [Re: Jay Ayala] #1077367 04/01/15 01:30 AM
JAVYPRO Offline OP
No problem man.
Question: I Noticed that the coolant passages in the block and heads are sort of oval and the gasket is round, covering most of the passage. Also noticed that because of this the head gasket kinda deteriorates in that same section. Is there a gasket that matches the passages on the block and heads?
https://onedrive.live.com/redir?resid=c2...int=photo%2cgif
Javy
88 red Montero with the Dakar Special Edition decals, 438,000 miles (As of 7/23/2012) some occational blue puffing but still strong and counting!!! I am going ppsshhh (turbo), Stay tuned =) ...
Re: Hi it has been a while. Now Head gasket issue 90 LWB [Re: JAVYPRO] #1077368 04/01/15 06:05 AM
Jay Ayala Offline
Javy, I know what you mean. I wondered about that as well. I went with the FelPro set that was recommended on their web site. I haven't had any problems with it over the past 12 months. I don't know if there is a set of gaskets that fit better or not. I wouldn't be too concerned about it. How long have you ran that head on the engine with that gasket?
Re: Hi it has been a while. Now Head gasket issue 90 LWB [Re: JAVYPRO] #1077369 04/02/15 05:46 PM
mrray Offline
Javi, it looks from the pics that there are perforations in the proper oval shapes on that gasket. Are you sure you're not supposed to punch them out?
1991 Montero LS (LWB) 3.0L V6 Stock 205K Miles
Re: Hi it has been a while. Now Head gasket issue 90 LWB [Re: mrray] #1077370 04/02/15 08:47 PM
Jay Ayala Offline
Javi,
I assume the till arrived today?
Re: Hi it has been a while. Now Head gasket issue 90 LWB [Re: mrray] #1077371 04/04/15 02:12 PM
JAVYPRO Offline OP
If you notice I circled some, the shape of the gasket and the head don't match. I thought the same thing, if I should punch hem to he head's shape or is it ok to leave them like that.
Jay, I got the tool, I am studying it to see how it works. Today is a beautiful Saturday in the good ol'south so I will be working on the truck soon.
I am thinking on taking a bit of time longer to paint and polish a couple of things under the hood. This is crazy but thinking on painting the intake manifold, red <img src="/forums/images/graemlins/scared.gif" alt="" /> crazy??? Ha ha ha
I am also going to redo the plastic piping that covers the fuel injectors wires it is brittle and disintegrating.
Oh, one question: I found the timing belt way too easy to slide out, is it supposed to have a bit more of tension on it? Can o adjust it? Should I?
Will have my pc in the garage together with some good Latin tunes and the little fridge with good beer so I will be posting the good as I go.
Javy
Re: Hi it has been a while. Now Head gasket issue 90 LWB [Re: JAVYPRO] #1077372 04/04/15 06:30 PM
Jay Ayala Offline
Punch them out.
Good now get to work! Use this as a guide. 1989 V6 - Valve Seal Replacement - Cylinder Heads Removed
No, you are not crazy. I painted mine yellow remember?
You may want to consider self wrapping conduit. It works well at high operating temperatures. You can find it cheap by the foot at Fry's and places that sell computer wiring like PCH Cables in Oregon. They sell 1/2" for $1.08 per foot and ship anywhere for cheap. I'm sure you can find it locally.
Yes, you should adjust it. Make sure the little spring that connects from the post on the water pump to the tensioner arm is there. Sometimes they break. It will pull the right tension on the tensioner pulley, then torque down the pulley. That is how you adjust the tension. Sometime I pull a little extra tension with a big screw driver on the back side of that pulley. Here is a link to Autozone's timing component kit. .
Javy
Keep us updated.
Re: Hi it has been a while. Now Head gasket issue 90 LWB [Re: Jay Ayala] #1077373 04/06/15 10:45 PM
Jay Ayala Offline
Javy, what's the latest? Did you get all that stuff done over the weekend?
Re: Hi it has been a while. Now Head gasket issue 90 LWB [Re: Jay Ayala] #1077374 04/19/15 03:27 PM
JAVYPRO Offline OP
Jay,
Wow I have been busy. Couldn't work on it last weekend end but I'm working on it as we speak.
LOL, I had to remove a stud that was broken on the exhaust manifold and I broke a bolt of the rocker arms bolt, this one I have to find.
The other thing is, once I torque the heads I don't want to remove the valve covers again to do the warm torque, common that is a pain in the <img src="/forums/images/graemlins/butwiggle.gif" alt="" /> as it is to remove. Did you do that warm torque or did you torque them a bit more to compensate?
Also, I painted the intake oh you got to see how it looks but I won't post pictures until installed <img src="/forums/images/graemlins/smile.gif" alt="" />
Javy
Re: Hi it has been a while. Now Head gasket issue 90 LWB [Re: JAVYPRO] #1077375 04/21/15 12:37 AM
JAVYPRO Offline OP
Contacted a friend of mine who is the best engine builder I know back home and he advised to just do the cold torque and to add 5lbs.
Mounting this thing back but can only work on weekends as I do not have enough time during the week. I think I am taking Friday off so I can finish it.
Oh, during the disassembly process I found a broken sensor, the one on top and next to the thermostat housing, I believe is for the cooling fan, and it cost about $47 so I'll see if I can fix it just as I did with one of the sensors in the transfer case.
Javy
PHP: 7.4.33 Page Time: 0.011s Queries: 15 (0.007s) Memory: 0.6486 MB (Peak: 0.7617 MB) Data Comp: Off Server Time: 2026-11-02 04:00:40 UTC
