Re: Thinking about swapping in a 1995 3.5L DOHC into my Gen I [Re: Jay Ayala] #1078102 05/18/15 04:18 PM
Just the engine, we swapped a gen 1 v6 bellhousing onto the original 4cyl transmission. Later PA_JERO swapped in a complete v6 lockup gen 1 trans and more recently we swapped in the Dana 44, Box4Rocks and Dana 20 transfercases.
Re: Thinking about swapping in a 1995 3.5L DOHC into my Gen I [Re: TOASTY] #1078103 05/18/15 08:16 PM
Jay Ayala Offline OP
Okay TOASTY,
With my 1989 3.0L automatic transmission stock, would it make sense to you then if I just swapped the engine and ECU harness along with some of the accessories?
Re: Thinking about swapping in a 1995 3.5L DOHC into my Gen I [Re: Jay Ayala] #1078104 05/18/15 08:19 PM
I'm not TOASTY, but I'll chime in here with a loud YES.
Re: Thinking about swapping in a 1995 3.5L DOHC into my Gen I [Re: Mudraider] #1078105 05/18/15 09:34 PM
Yeah dude! you're going to be awesome.
Re: Thinking about swapping in a 1995 3.5L DOHC into my Gen I [Re: TOASTY] #1078106 05/19/15 06:46 AM
Okay guys,
This is becoming more real for me now. Just working through some of the stats on these engines, this is what I have found so far.
6G72 (3.0L SOHC - 4x4Wire)
89-91 6G72 3.0 SOHC V6 12 MPI 143@5000 168@2500
6G74 (3.5L DOHC - 4x4Wire)
94-96 6G74 3.5 DOHC V6 24 MPI 215@5500 228@3000
With the torque difference, should I expect transmission problems? Perhaps having a tranny shop overhaul it may be a good call.
Re: Thinking about swapping in a 1995 3.5L DOHC into my Gen I [Re: Jay Ayala] #1078107 05/19/15 07:11 AM
You know, I've been giving this a lot of thought lately. What would it look like for my power to weight ratio?
Let's run those numbers, shall we?
My current power to weight ratio: 24.4
My target power to weight ratio: 16.2
Re: Thinking about swapping in a 1995 3.5L DOHC into my Gen I [Re: Jay Ayala] #1078108 05/19/15 09:24 PM
Your V6 trans will be fine especially if it'a a lockup, put a new front seal in and run it.
Re: Thinking about swapping in a 1995 3.5L DOHC into my Gen I [Re: TOASTY] #1078109 05/19/15 09:34 PM
There you go. Are you done yet? <img src="/forums/images/graemlins/lol.gif" alt="" />
PHP: 7.4.33 Page Time: 0.012s Queries: 15 (0.009s) Memory: 0.6308 MB (Peak: 0.7137 MB) Data Comp: Off Server Time: 2026-07-16 13:25:32 UTC
