What happened to my post ... #1078999 09/16/15 03:15 PM
KB2IAW Offline OP
I Posted a question looking for help and my post never appeared ???
1994 montero SR 3.5 v6
City Of Hills Oneonta N.Y. FREEDOM HAS A TASTE,AND FOR THOSE THAT HAVE FOUGHT FOR IT, THE TASTE IS SO SWEET , THE PROTECTED WILL NEVER KNOW .
VENI VEDI DECI <oneontasportsmenclub.net>
Re: What happened to my post ... [Re: KB2IAW] #1079001 09/16/15 03:37 PM
4x4Wire Offline
According to system logs, this is your first fist since 01/29/2011...
When did you try to post?
John Stewart
Editor - 4x4Wire.com
Editor - 4x4Voice
Editor - MUIRNet-News
Re: What happened to my post ... [Re: KB2IAW] #1079003 09/16/15 06:12 PM
danz91crx Offline
I've forgot to hit "submit" after previewing before. Why not ask your question again?
I'm like 20mins from Oneonta by the way also in Otsego Co
1990 LWB RS A/T
1990 LWB Base A/T
1991 LWB LS A/T Going...Going...
Re: What happened to my post ... [Re: KB2IAW] #1079009 09/17/15 04:24 PM
KB2IAW Offline OP
blush O.K. Mia Culpa I Forgot To Put In A Topic ??
sorry ...But I Did Find The Answer to my question which was ,
About the lower plenum and the six butterfly valves ...and if anyone has tried to resolve the problem differently than replacing everything ...
MITSUBISHI and it`s dealers are no help ...but you most likely know this !!!
I have come to find out that an auto engineer calls this system ( OLD TECHNOLOGY ) He said You Can Either remove said valve system or keep them fixed in an open position , they were designed to help with cold air and modulate as air temp changes ....not really necessary on low torque /low powered engines ...there may be some gas mileage changes but these cars are not economy anyway ... thanks for the responce ...Oneonta ,ny city of the hills
Re: What happened to my post ... [Re: KB2IAW] #1079011 09/17/15 10:08 PM
Yup, can either remove them, find a way to lock them in place or replace the whole assembly. I toyed with the idea of swapping in a different bushing fabricated from sintered bronze or some similar solution that was as permanent and reliable but simply didn't have the time nor inclination to really flush that all out and do it.
Re: What happened to my post ... [Re: KB2IAW] #1079024 09/19/15 12:35 PM
plh Offline
Oneonta!
  • '83 Might Max: IG @83mmax
  • '88 Raider: my OG
  • '89 Raider: rescued
  • '92 RS M/T: sold
  • '93 SR: sent to crusher
  • '05 Montero LTD: sold
  • '18 PHEV: wife's daily
  • '14 OL GT
  • http://www.tuffpans.com
Re: What happened to my post ... [Re: KB2IAW] #1102013 09/06/16 07:10 AM
marksroberts61 Offline
I removed the valve plates, clamped the shaft into my vise and had at it with a hacksaw. I reinstalled the dashpot (what those vacuum actuators are called) onto the front of the plenum to keep the smog guys happy, and went on my way. I haven't noticed any difference. It had been repaired once before. Too bad Mitsu didn't put sealed bearings in the darn things to begin with!
1995 SR, dark blue, cloth seats, flare and cladding delete, upcoming sunroof delete,10 Guage custom skid plates, ham radio
Re: What happened to my post ... [Re: KB2IAW] #1102015 09/06/16 06:05 PM
Originally Posted by KB2IAW
blush O.K.
I'm sorry, but this makes absolutely no sense to me. My understanding is it has to do with how deep your foot is in the throttle, and how the air is allowed in. "Modulate with temperature changes?
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.003s) Memory: 0.6254 MB (Peak: 0.7247 MB) Data Comp: Off Server Time: 2026-05-30 02:18:28 UTC
