Page 3 of 4 1 2 3 4
Re: 94 Montero SR head-gasket project. [Re: mynion] #1079382 10/25/15 08:47 PM
mynion Offline OP
Thanx Dart, yes I have most of everything tagged and bagged.the bolts and valves are all indexed, listed by sides. Im about ready to start resembling. Heads are unwarpped by the blown gasket, used a scotch-bright pad and the deck's look like new.
also reground the exhaust valves, and lapped both the intake and exhaust.
Half the hydraulic lash adjusters were frozen, soaked all of them in desiel, popped the caps, used a straight pick down the middle and pushed the ballvalve down and got all the old oil out. Wishing Id taken pics of that, my bad, was cool really cool actually.
Picked up a new motorcycle, an 02 shadow. getting rid of the Katana soon. Thats my Monty in the background.
94 montero SR 3.5. 33" BFG TA KO's, OME HD rear springs, front T-bar crank.
93 600 Katana. stage 1 jet kit, Uni foam air filter
02 honda shadow. "for when the woman wants to go with"
97 Acura Integra.
Re: 94 Montero SR head-gasket project. [Re: mynion] #1079416 11/01/15 10:02 PM
mynion Offline OP
I think Im going to hunt down and KILL the PO... Im guessing he lost the cam cap bolts and just grabbed whatever fit, and this is the result...
If you look close you can see the two bolts are different.
not sure if you can tell, but thats the stripped hole, stripped at 14 FtLbs...
here we have the aluminum threads and the helacoil that's going in
And torqing the other head I found 2 more that stripped, Its my guess that those bolts are stripping the head because the bolt threads dont go all the way down... Id be
Bolting the heads back on this week if it weren't for this. !@#$%%!@#$%^&*()_ Ect.
97 Acura Integra.
Re: 94 Montero SR head-gasket project. [Re: mynion] #1079417 11/02/15 12:34 PM
JAVYPRO Offline
Wait, wait, wait are the rocker arms under the cams? stripped bolts I feel your pain, I had to fix 4 when doing the top of my 3.0L.
Bolts next to the firewall? LOL the 3.0L also have some bolts that hold the intake plenum on the drive's side that I cannot understand how someone can fit their hand back there and brackets? WOW, I admire Mitsubishi for all the multitude of brackets to hold and mount "stuff".
I love the look of that DOHC 3.5L
Excellent pics.
Javy
88 red Montero with the Dakar Special Edition decals, 438,000 miles (As of 7/23/2012) some occational blue puffing but still strong and counting!!! I am going ppsshhh (turbo), Stay tuned =) ...
Re: 94 Montero SR head-gasket project. [Re: mynion] #1079424 11/03/15 06:52 AM
mynion Offline OP
Thanks, ya roller rockers under cam's.
Exhaust cam is setup to make sure it rotates smoothly.
97 Acura Integra.
Re: 94 Montero SR head-gasket project. [Re: mynion] #1079906 01/30/16 07:35 PM
mynion Offline OP
Reassembly is progressing, headers are back on, the coolant pipe that goes to the back of the heads... that was a B*tch, but its on, new hoses on the back of the engine. It's slow going because I'm both working and spring semester in college has started back up, so between the 15 units and working full time I have one-half day I can usually commit to it... but slow and steady.
97 Acura Integra.
Re: 94 Montero SR head-gasket project. [Re: mynion] #1079947 02/07/16 05:58 AM
mynion Offline OP
Got the crank pully on, got the accessory pulley on, got the AC bracket and AC compressor on, realised Id forgotten to run the crank sensor behind the main accessory bracket... I think Im going to have to backtrack...
Tried to post pics the other day, but it didn't seem to be working.
97 Acura Integra.
Re: 94 Montero SR head-gasket project. [Re: mynion] #1079948 02/07/16 05:59 AM
mynion Offline OP
does anyone know if I can thread it through without pulling it back off?
97 Acura Integra.
Re: 94 Montero SR head-gasket project. [Re: mynion] #1079992 02/15/16 02:54 AM
mynion Offline OP
Well, that might have been a pain, oH, and looking at it I probably could have threaded the sensor wire through. Anyway, plugging in the injectors today, and one set is blue, and one is brown, and the manual doesn't say which was which, fortunately, I took pictures, and in the corner of one pic I could see the connector for one of the pass side injectors, and it was brown, which is opposite of the way I had it setup, so... Ya, small issues, could have been a real pain later. Oh, well there was the usual dropping things down below the lower intake manifold, one injector clip, and two of the plastic isolators... which being plastic, ignored the magnet... lol
97 Acura Integra.
Re: 94 Montero SR head-gasket project. [Re: mynion] #1079993 02/15/16 03:47 AM
Originally Posted by mynion
...... Also, anyone have an extra harmonic balancer laying around I can take off your hands? 94 SR.
I have an SR harmonic balancer. $45 + shipping. Lemme know
Re: 94 Montero SR head-gasket project. [Re: mynion] #1079994 02/15/16 07:04 AM
mynion Offline OP
I ended up getting one from rockauto I think it was like 110, otherwise Id be all over that, did I post the pic where the PO had welded on part of the pully?
97 Acura Integra.
Page 3 of 4 1 2 3 4
PHP: 7.4.33 Page Time: 0.010s Queries: 15 (0.007s) Memory: 0.6416 MB (Peak: 0.7530 MB) Data Comp: Off Server Time: 2026-07-13 09:43:42 UTC
