anyone have pics of stock oil cooler set up?
#1079201
10/05/15 02:53 AM
Reading thru through the FSM and just realized the PO had the oil cooler deleted and a hose loop installed. While mine's apart, would appreciate some pics of how it's run. The FSM drawings sucking for that kind of thing.
Re: anyone have pics of stock oil cooler set up?
[Re: Mudraider]
#1079204
10/05/15 05:24 AM
I somehow doubt my 94 sr oil cooler pics will help, but if they will I will be glad to post
94 montero SR 3.5. 33" BFG TA KO's, OME HD rear springs, front T-bar crank. 93 600 Katana. stage 1 jet kit, Uni foam air filter 02 honda shadow. "for when the woman wants to go with" 97 Acura Integra.
[Re: Mudraider]
#1079210
10/05/15 10:49 PM
Ah crap, thanks. 89 SWB 3.0
[Re: Mudraider]
#1079218
10/06/15 04:02 PM
The lines are mounted to the body under the air filter when they go from rubber to metal off the filter bracket Through a hole in front ![[Linked Image]](http://i1070.photobucket.com/albums/u482/danz91crx/IMG_20151006_114314.jpg) To the oil cooler mounted horizontally behind the grill The upper line on the filter bracket goes to the lower point of the cooler
1990 LWB RS A/T 1990 LWB Base A/T 1991 LWB LS A/T Going...Going...
