Page 6 of 6 1 2 3 4 5 6
Re: EURO, ***** & USA CAPS [Re: OldColt] #904357 03/11/09 04:20 PM
I haven't tried it but perhaps you could simply install a Europe instance of wincaps under c:/WincapsEur and the Japan wincaps under c:/WincapsJap, etc. Then change the configuration/setup screen for each instance to look for the data set in the corresponding directory. <img src="/forums/images/graemlins/kewl.gif" alt="" />
Re: EURO, ***** & USA CAPS [Re: off-roader] #904358 03/11/09 05:00 PM
That sounds like the way. I have put each dataset in a separate folder in the wincaps directory. I guess a manual entry in setup to link each but am curious if there is a way to toggle directories such as with the F keys.
I seem to be getting weaker in my DOS setups.
Re: EURO, ***** & USA CAPS [Re: OldColt] #904359 03/11/09 05:06 PM
Ahh, I think I might have it, the F8 key is CD switch.
Re: EURO, ***** & USA CAPS [Re: OldColt] #904360 03/11/09 05:17 PM
Outstanding Red Team! I will try all this as well. Assuming I can repeat across them, I'll look to add a ReadMe to the ZIPs I have posted up. May take me a few to get to it...
Re: EURO, ***** & USA CAPS [Re: MontyMcV] #904361 03/11/09 05:38 PM
I almost have it,
i copy and pasted the path to each file, Caps did not seem to want the final directory included as it's original path shows.
When I toggle I do get a different list of cars but I do get an error message about loading the CD.
So I am close but not there yet.
Re: EURO, ***** & USA CAPS [Re: MontyMcV] #904362 03/12/09 06:58 PM
Oh boy I did it now, Yesterday I had caps switching between data sets but not fully opening the other sets. It gave me the list of car lines but I could not get any further.
Well today, I just opened Wincaps and it opened in Japenese. Humm, so I opened the setup, easy since it is the bottom of the file column. Fine but it gives me a different selection and all in ???????. It will not convert languages.
I guess I will be a bit delayed in getting todays parts order called in.
Re: EURO, ***** & USA CAPS [Re: TOASTY] #1079316 10/16/15 03:46 AM
mynion Offline
apparently doesnt work with 64x windows, working on fix
94 montero SR 3.5. 33" BFG TA KO's, OME HD rear springs, front T-bar crank.
93 600 Katana. stage 1 jet kit, Uni foam air filter
02 honda shadow. "for when the woman wants to go with"
97 Acura Integra.
Re: EURO, ***** & USA CAPS [Re: mynion] #1079319 10/16/15 05:19 AM
danz91crx Offline
ASA Version 1.3.0.2 working fine on windows 7 x64 for me
1990 LWB RS A/T
1990 LWB Base A/T
1991 LWB LS A/T Going...Going...
Re: EURO, Japan & USA CAPS [Re: TOASTY] #1104302 04/29/18 01:58 AM
chadzeilenga Offline
Hi All,
Is the Mitsubishi CAPS/ASA program still available? I cannot seem to get any of the downloads or links to work?
PHP: 7.4.33 Page Time: 2.542s Queries: 16 (0.009s) Memory: 0.6382 MB (Peak: 0.7574 MB) Data Comp: Off Server Time: 2026-07-15 11:16:38 UTC
