Clunk and occasional squeak #1079359 10/23/15 12:30 AM
Dartmouthbrian Offline OP
So I did a search here and found a little, but not a lot.
On my 91 Montero I occasionally hear a clunk in the front kind of under the passenger seat area. It definitely squeaks here and there. Seems like the clunking is a mystery from other posts Ive read...
I lube the entire chassis per the manual. Some cracked rubber, so I know that stuff will need replacing.
As for the clunking. Could that be the lower ball joints? How can I tell?
Or do you all have other suggestions?
91 Montero RS
90 Montero base
Re: Clunk and occasional squeak [Re: Dartmouthbrian] #1079364 10/23/15 04:39 PM
Put on a lift and move the parts underneath. In mind I had an annoying clunk when the suspension cycled. Turned out to be worn bushings on the front anti-sway bars.
Re: Clunk and occasional squeak [Re: Dartmouthbrian] #1079372 10/24/15 05:23 AM
Thanks off-roader. Much appreciated
91 Montero RS
90 Montero base
PHP: 7.4.33 Page Time: 0.008s Queries: 15 (0.006s) Memory: 0.5923 MB (Peak: 0.6462 MB) Data Comp: Off Server Time: 2026-07-13 19:20:30 UTC
