Rating: 5
Page 16 of 17 1 2 14 15 16 17
Re: New and Improved!!! "Pay It Forward 2010" A thread of goodwill, and freebies [Re: fhuzz] #1079632 11/26/15 08:26 PM
I might have a shifter, but nothing deeper into the t-case without opening one up.
Re: New and Improved!!! "Pay It Forward 2010" A thread of goodwill, and freebies [Re: rxinhed] #1079639 11/30/15 06:31 PM
F
fhuzz Offline
I should clarify. It's a part of the 'linkage' that is external to the t-case running under and perpendicular the transmission.
A metal rod connected between two other metal rods, with a spring running inside the middle rod.... I hope that makes sense.
A while ago I had some work done on the transmission and this rod and associated inner spring have a lot of slack.
'89 Monty LWB auto, 3rd row seating, 95SR rear + coils, genII UCA's and calipers/rotors, dual bouncies.
Re: New and Improved!!! "Pay It Forward 2010" A thread of goodwill, and freebies [Re: LandRaider] #1079658 12/03/15 09:10 PM
Maciek Offline
$10 should cover it
~M
'88 Raider - 250+K | 2.6L G54B; no balance shafts, non jet-valve head, ARP head studs| Weber 32/36 DFEV | Pacesetter 4>1 | 2 1/4" magnaflow | 32" BFG A/T | 2" bar crank & add-a-leaf | +2 SkyJackers | bumpstop del | Optima Yellow-Top | Curt GenII receiver
Re: New and Improved!!! "Pay It Forward 2010" A thread of goodwill, and freebies [Re: LandRaider] #1079659 12/03/15 09:28 PM
Maciek Offline
welcome newbie, sorry i dont' check in often, but if JAYVYPRO already got one this one's yours.
Head issues are pretty common on the 2.5. Check the torque on the head bolts. If it is cracked I would look in to the jet-valve free head. There are some options there, some castings are better than others, but any is better than stock with jet valves. Pricing varies too, complete ready to go can get expensive (especially if you look at fancy valve, spring, and rocker/lifter options), and bare castings aren't that cheap unless you can do the valve work yourself. I got mine for less than 300 (not incl core) (from Odessa cylinder head) set up with stock valves and springs, so all I had to do was check the oil passages are all clear and swap my rocker train over and it was good to go. Even got it through emissions here in WA a couple times before it got old enough not to require it anymore.
GL
~M
Re: New and Improved!!! "Pay It Forward 2010" A thread of goodwill, and freebies [Re: LandRaider] #1101908 08/17/16 07:21 PM
bahamaraider Offline
new to this forum
I am looking for a drivers side vent window and passenger side mirror for my 87 dodge raider.....any info would be greatly appreciated. it seems the mirrors are rare.
good morning
I have a red 1987 dodge raider....bought it 3 years ago...only major problem was the carburetor...went to a weber and had no problems since then....working for the navy in the Bahamas...my raider is perfect for the island.
Re: New and Improved!!! "Pay It Forward 2010" A thread of goodwill, and freebies [Re: LandRaider] #1101909 08/17/16 11:44 PM
This is a thread about paying it forward and giving things away to the community, If you are wanting parts you should try the wanted section OR read through this thread and find someone giving the parts you want away and contact them directly.
Re: New and Improved!!! "Pay It Forward 2010" A thread of goodwill, and freebies [Re: LandRaider] #1103936 10/20/17 02:43 AM
Back from the dead again, this thread.
I have a Montero Sport parts car aching to donate useful things
Re: New and Improved!!! "Pay It Forward 2015" A thread of goodwill, and freebies [Re: LandRaider] #1104766 12/28/18 01:02 PM
Bigshankhank Offline
Reopening this thread if I may.
Couple things I am looking for, and I haven't had my Raider long enough to build up a stock of spares but;
I do have a spare voltage meter/gauge, oil pressure gauge and housing. The inclinometer is there but the body of it cracked and the fluid is gone so it no longer floats.
I am hoping someone has a driver's side mirror, and/or a rear wiper arm.
Thanks.
1989 Dodge Raider V6
2001 Jeep Wrangler 4.0L
2008 Toyota 4-Runner SR5 4wd
Re: New and Improved!!! "Pay It Forward 2015" A thread of goodwill, and freebies [Re: LandRaider] #1104767 12/30/18 11:42 PM
What mirror? The plastic flag mirror or metal 2-point mount?
What color is the gauge housing?
Re: New and Improved!!! "Pay It Forward 2015" A thread of goodwill, and freebies [Re: rxinhed] #1104769 12/31/18 02:35 PM
I found a replacement mirror, so I am square on that.
The housing is standard white plastic, be advised I am not including the vinyl shroud/cover that matches the interior of my truck.
PHP: 7.4.33 Page Time: 0.014s Queries: 16 (0.012s) Memory: 0.6475 MB (Peak: 0.7724 MB) Data Comp: Off Server Time: 2026-07-17 05:09:58 UTC
