Page 3 of 3 1 2 3
Re: 2001 Cherokee Transmission FITS 1999 Montero Gen 2.5 [Re: ES_97Sport] #1079811 01/06/16 07:46 AM
Ian Sharpe Offline
Originally Posted by ES_97Sport
[quote=Ian Sharpe][quote=ES_97Sport]..
Ok, so you just used a pipe plug for the drain fitting? NWF uses a fitting that uses much smaller hose. Hmmmm. Dang! I was hoping to not have to involve a machine shop this go-around.
Did the Strong Box guys specify ATF or synthetic gear oil? I noticed that NWF says 80-90 full synthetic gear oil. Doesn't seem right to me. I remember talking to Duffy about this but I don't remember what we talked about. He specified the same full synthetic AFT that you normally put in a NP231.
yes , just a normal 1/2"bsp plug with some teflon tape. The aluminium housing is easy to drill & tap.
Jacob said 70w gear oil or atf.
Given that my tranny had atf & the NP242 uses atf AND I was not confident with the internal sealing of the Strong Box as it leaked out of the back seal when I had it set up but not installed , I went for atf all round so if there was any internal leakage of fluid then it wouldnt matter as all 3 components had the same fluid. So far no problems
97 Exceed, 3.5l SOHC auto, 4.90 gears, ARB front locker,rear Harrop E-Locker, Magnum winch, dual transfer cases also 2008 NS swb Pajero, front bar & winch
Re: 2001 Cherokee Transmission FITS 1999 Montero Gen 2.5 [Re: Ian Sharpe] #1079826 01/08/16 08:39 PM
ES_97Sport Offline
Originally Posted by Ian Sharpe
[quote=ES_97Sport][quote=Ian Sharpe]yes , just a normal 1/2"bsp plug with some teflon tape. The aluminium housing is easy to drill & tap.
Ok. Cool. I need to unbox this thing and take a look at it. smile
That's what I was thinking. I seem to remember that was what Duffy and I were talking about and why he recommended ATF. I've never had a leak problem that I know of but that's always been a concern of mine.
I think I'll shoot an email off to NWF and ask what the reasoning for gear lube is in their crawl box. I think if I had a leak between the A/T and crawl box I'd prefer that the crawl box was running ATF rather than gear lube. smile
Re: 2001 Cherokee Transmission FITS 1999 Montero Gen 2.5 [Re: vectorsc] #1079831 01/09/16 08:33 PM
JAVYPRO Offline
Can any of them be mated to a 2.6L?
Javy
88 red Montero with the Dakar Special Edition decals, 438,000 miles (As of 7/23/2012) some occational blue puffing but still strong and counting!!! I am going ppsshhh (turbo), Stay tuned =) ...
Re: 2001 Cherokee Transmission FITS 1999 Montero Gen 2.5 [Re: JAVYPRO] #1079832 01/09/16 09:08 PM
ES_97Sport Offline
I don't know. I only deal wit the 3 and 3.5L. One of the other guys should.
Page 3 of 3 1 2 3
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6149 MB (Peak: 0.6726 MB) Data Comp: Off Server Time: 2026-05-29 22:28:35 UTC
