1987 dodge raider build #1079833 01/10/16 01:58 AM
raider93 Offline OP
just recently picked up a 1987 dodge raider in fair shape but dont like the original 2.6 engine. i have found a donor vehicle a 1987 Toyota pickup with a 22re fuel injected with a 5spd transmission
i was curious how easy it would be to switch out the 2
Re: 1987 dodge raider build [Re: raider93] #1079850 01/15/16 01:41 AM
Cutting torch and a stick welder. Do you have the Toy trans and transfer case? Isn't the front shaft on wrong side though?
Re: 1987 dodge raider build [Re: Mudraider] #1079851 01/15/16 03:56 AM
Toasty did a conversion using the 2.4L Mitsu FI engine. Will be easier than a Toyota swap.
Rich is doing a 5.3L Chevy engine swap in his '89 Raider.
Others have the Starion 2.6L turbo.
Re: 1987 dodge raider build [Re: rxinhed] #1080106 03/13/16 12:53 AM
goobuds Offline
and of course you have the 2.3 and 2.5 diesel swap .
owned a few .. current 86 rustbucket 2.5td . manual hubs
Re: 1987 dodge raider build [Re: raider93] #1080114 03/14/16 09:53 PM
Shreedo47 Offline
Has anyone ever tried the Mitsubishi 3000Gt engine for a swap? just curious.
1989 Dodge Raider, V6/Auto, 124k original miles. New proud owner
Re: 1987 dodge raider build [Re: raider93] #1080118 03/15/16 08:47 AM
That is the same engine as the Montero had in it in the later models, the 6G72. It can be done. With a Montero donor vehicle, that isn't too bad of a swap. Weld in motor mounts, throw the wiring harness in, fuel pump for efi, 90% of the work is done.
PHP: 7.4.33 Page Time: 0.010s Queries: 15 (0.008s) Memory: 0.6081 MB (Peak: 0.6779 MB) Data Comp: Off Server Time: 2026-07-14 01:53:23 UTC
