Re: 1989 Dodge Raider 3.0 evil oil leak back! [Re: mfarmer10] #1080314 04/12/16 11:36 PM
Test for spark at the coil. Pull the coil wire at the distributor, insert a screwdriver in the connector, hold it 1/4" inch from engine metal, and crank it. Do NOT let the metal of the screwdriver touch you, or the experience will be memorable. Spark should jump the gap,blue-white and hot, 3 sparks per engine revolution. Repeat with a wire pulled from a handy plug.
Re: 1989 Dodge Raider 3.0 evil oil leak back! [Re: fasteddy] #1080396 04/25/16 03:42 PM
mfarmer10 Offline OP
So the pcv system wasn't backed up, what else could be causing this excess pressure?
Re: 1989 Dodge Raider 3.0 evil oil leak back! [Re: mfarmer10] #1080399 04/25/16 08:53 PM
cheesegrater Offline
Rings?
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.5996 MB (Peak: 0.6526 MB) Data Comp: Off Server Time: 2026-06-07 06:56:13 UTC
