Upgrade Lash Adjusters? #1080703 05/16/16 05:15 PM
P
pcc Offline OP
My truck has developed a coolant leak, not exactly sure where yet - but front PS above power steering bracket. So the decision is to do a full timing belt/valve seal service since it's been about 60K miles/2006.
I thought I might look at replacing the original valve lash adjusters with the new design (larger hole) that is said to not tappy-tappy.
I've done a search in forums and in tech section but I cannot find the part number/source for the new adjusters, OEM or aftermarket.
There are several options on RockAuto, EngineTech, DNJ, Sealed Power, but none say if these are the ones with the larger hole.
Help anyone?
Re: Upgrade Lash Adjusters? [Re: pcc] #1101300 05/19/16 06:15 PM
P
pcc Offline OP
I'm in contact with EngineTech who are a source for Montero lash adjusters. They're checkin to see if they can confirm the ones they supply are the larger bore or not.
In the meantime they sent me a picture of their adjuster with the bore diameter noted. If anyone has an old OEM adjuster laying around maybe you can measure the bore diameter so I can compare it.
Re: Upgrade Lash Adjusters? [Re: pcc] #1101301 05/19/16 06:20 PM
ryany Offline
If memory serves, the 3mm hole is the upgraded style.
95 Montero SR
Re: Upgrade Lash Adjusters? [Re: pcc] #1101303 05/19/16 11:07 PM
PHIL_ Offline
Sorry, threw mine away not that long ago. Boooo... 3mm sounds bigger than what was in mine, so I bet Ryan is right, and they're upgraded...
Don't forget to bleed the new ones before install! (Like you'd ever do that after going to the trouble of unearthing them, right? :D)
Do you have any experience changing VLA's? The bicycle tube trick works great to keep everything in place as you go...
Re: Upgrade Lash Adjusters? [Re: PHIL_] #1101304 05/20/16 12:40 AM
ryany Offline
95 Montero SR
Re: Upgrade Lash Adjusters? [Re: pcc] #1101305 05/20/16 01:26 AM
Re: Upgrade Lash Adjusters? [Re: pcc] #1101310 05/20/16 02:35 AM
Rubber glove fingers.
Re: Upgrade Lash Adjusters? [Re: PHIL_] #1101312 05/20/16 10:15 AM
P
pcc Offline OP
The last TB I did I had the cams off to install valve seals. It seems I did not have much trouble re-installing adjusters, but I have read about using rubber glove finger tips to hold everything in place and will try this time.
Re: Upgrade Lash Adjusters? [Re: ryany] #1101313 05/20/16 10:18 AM
P
pcc Offline OP
Yes Ryany, I've seen ads for the Mitsu 3000 lifters, but none for Montero, other than parts on RockAuto. But the link does say 3mm is large bore.
Thanks
Re: Upgrade Lash Adjusters? [Re: fasteddy] #1101333 05/23/16 12:05 PM
Brilliant!!!!!!
PHP: 7.4.33 Page Time: 0.006s Queries: 16 (0.004s) Memory: 0.6426 MB (Peak: 0.7630 MB) Data Comp: Off Server Time: 2026-06-23 07:26:22 UTC
