85 pickup gear ratios #1082191 04/14/04 07:56 AM
dewmtndew Offline OP
hey I was wondering if anyone could tell me what gear ratio an 85 4x4 pickup has? thanks alot!
erick
85 Pickup
33s, lift, EB cam, header, exhaust...
Re: 85 pickup gear ratios [Re: dewmtndew] #1082192 04/22/04 03:38 AM
What does your driver side door jamb say? I need the "Axle Code" on the the tag to know. I also need to know if it's 4x4 or 2wd. I need this info, because depending on make/model/type, you can have from 3.27 to 4.375. The code should say CA## (example: CA41 means you have the C200 rear axle, with 4.111:1 diff gears).
Re: 85 pickup gear ratios #1082193 04/22/04 05:05 PM
its a 4x4, st model i think. Its my friends truck so next time i talk to him i will check the door jam.
erick
85 Pickup
Re: 85 pickup gear ratios [Re: dewmtndew] #1082194 05/06/04 02:32 AM
Any luck? More than likely u have 4.11. That's what most Datsun/Nissan 720 series trucks came with.
Moderated by  4x4Wire, Dandeman, Mike Bondi
PHP: 7.4.33 Page Time: 9.277s Queries: 15 (0.003s) Memory: 0.5950 MB (Peak: 0.6541 MB) Data Comp: Off Server Time: 2026-06-22 07:37:21 UTC
