85 pickup gear ratios
#1082191
04/14/04 07:56 AM
hey I was wondering if anyone could tell me what gear ratio an 85 4x4 pickup has? thanks alot!
erick
85 Pickup 33s, lift, EB cam, header, exhaust...
Re: 85 pickup gear ratios
[Re: dewmtndew]
#1082192
04/22/04 03:38 AM
What does your driver side door jamb say? I need the "Axle Code" on the the tag to know. I also need to know if it's 4x4 or 2wd. I need this info, because depending on make/model/type, you can have from 3.27 to 4.375. The code should say CA## (example: CA41 means you have the C200 rear axle, with 4.111:1 diff gears).
#1082193
04/22/04 05:05 PM
its a 4x4, st model i think. Its my friends truck so next time i talk to him i will check the door jam.
erick
[Re: dewmtndew]
#1082194
05/06/04 02:32 AM
Any luck? More than likely u have 4.11. That's what most Datsun/Nissan 720 series trucks came with.
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.003s) Memory: 0.5935 MB (Peak: 0.6525 MB) Data Comp: Off Server Time: 2026-06-07 00:26:52 UTCValid HTML 5 and Valid CSS
