01 pathfinder misfiring
#1082571
09/15/13 11:51 PM
Intermittent misfire. Happens at idle and around 2500 rpm. Can coils cause intermittent misfires. The coils all test good with ohm meter. The nismo forum says yes, they can test good but still be bad. I am going to test the wiring from the computer to the coils next. Fuel system has been gone through with a fine tooth comb every thing checks out. The only code it is throwing is random multiple misfire. I don't want to just drop $300 for coils. Please share your thoughts.
99 Montero....15mpg! Sold (so sad) 02 Jetta TDI....48mpg! 03 2500 Ram QCLB Cummins....18mpg 02 2500 Yukon XL, We out grew the montero, at least it has one locker.....13mpg (sold) 01 montero limited
Re: 01 pathfinder misfiring
[Re: motero]
#1082572
09/22/13 03:37 AM
As a coil ages, it can have a break down the electromagnetic shielding inside and create multiple firing events. Any chance to use wrecking yard parts, rather than new?
PHP: 7.4.33 Page Time: 0.010s Queries: 15 (0.008s) Memory: 0.5884 MB (Peak: 0.6371 MB) Data Comp: Off Server Time: 2026-07-14 12:32:56 UTCValid HTML 5 and Valid CSS
