ignition control module 1992 d21 2.4 #1082573 05/11/14 03:46 PM
bearingman Offline OP
Can anyone advise where this is located? Auto Zone component location said behind driver's side headlight. Coil is there. I thought these were in distributor. Cranks fine when cold, but must sit hours before restart.
Is mounted on bottom side of coil, under a bunch of crap, of course. Didn't have enough light/downtime to swap it out yet. 4 day weekend coming, so I should be good to go
Re: ignition control module 1992 d21 2.4 [Re: bearingman] #1082574 06/08/14 01:33 AM
got it swapped out rather easily once I could see what I was doing. Cranks fine. Later went ahead and changed dist cap and rotor. Also changed out a vacuum line I found with 2 holes in it. Runs better and a little better on gas too.
Moderated by  4x4Wire, Dandeman, Mike Bondi
PHP: 7.4.33 Page Time: 0.008s Queries: 15 (0.006s) Memory: 0.5875 MB (Peak: 0.6355 MB) Data Comp: Off Server Time: 2026-07-14 12:32:30 UTC
