Page 4 of 42 1 2 3 4 5 6 41 42
Re: The ISUZUwharrie Spring 4xFun-Run ( North Carolina ) [Re: WillV] #1094314 01/07/05 01:29 AM
TrooperJ Offline
OH OH!!! i get to answer it first!!
Yes, your rodeo will be fine. I was told (many times <img src="/forums/images/graemlins/ignore.gif" alt="" />) that my stock trooper could make it over 95% of the trails with a good spotter. And besides, SOMEBODY will have a shotgun or tailgunner seat if you want to ride along for a while and get the feel of it. There are some pretty mild trails there, so youll have no problem. Oh and if you go, make sure to stop by The Outpost. They have great sausage and gravy and biscuits...
-J <img src="/forums/images/graemlins/kewl.gif" alt="" />
Man, i am going to go crazy if i cant go this time!! <img src="/forums/images/graemlins/lol.gif" alt="" />
Jordan Brown in Athens Georgia
The 2007 budget for the US Military covers Jack Bauer, two pistols and four billion rounds of ammunition.
Re: The ISUZUwharrie Spring 4xFun-Run ( North Carolina ) [Re: TrooperJ] #1094315 01/07/05 02:06 AM
Iluvmud Offline
I took my compleetly stock 95 rodeo down there in fall of 03. There is 1 trail that u will not have any probs with (u will band your skid plate a few times but that is what they are there for). Several other trails are doable but like J said, u need a spotter and some hexnuts of steel. Then there are 2 trails i can think of that u will need to ride shotgun for... and there is always an open seat some where. U are guarenteed to have a good time if u come. Heck, alot of people with the more "advanced" rigs come mainly just to hang out with a kick azz group of people.
8 inches of lift, 33s, custom bumpers and rockbars, powertrax, T-maxx 9000, lots o lights, and some bass in the trunk
Lifted, locked, and ready to rock!!! <img src="/forums/images/graemlins/evil.gif" alt="" />
[url=http://www.cardomain.com/memberpage/743285][/url]
Re: The ISUZUwharrie Spring 4xFun-Run ( North Carolina ) [Re: Iluvmud] #1094316 01/07/05 08:31 AM
Smiley Offline OP
...just to hang out with a kick azz group of people.
Robby, you saved the very best line for last! <img src="/forums/images/graemlins/kewl.gif" alt="" />
Will,
DonÆt worry û Whether youÆre driving your own rig, or riding in someone elseÆs (or both)à YouÆll have a blast!
I do recommend that you get a CB radio (even a cheap one from Wal-Mart like mine) û ItÆs a very handy device out on the trails. û Over and above its value as a legitimate communications tool, IÆm sure you would hate to miss out on all of our conversations and humorous banter.
[color:"white"][ Attendance List Updated ][/color]
<img src="/forums/images/graemlins/smile.gif" alt="" />
Six Isuzus, so far... still have three of them.
Re: The ISUZUwharrie Spring 4xFun-Run ( North Carolina ) [Re: Smiley] #1094317 01/07/05 04:27 PM
WillV Offline
That was my next question. <img src="/forums/images/graemlins/smile.gif" alt="" />
If I had to pick my battles, what things would you guys recommend doing to the Mule before heading south? Sounds like a CB is a must have. Anything else - the ground rules are:
Something that can be accomplished by a hack mechanic in his suburban garage for under a couple hundred bucks. <img src="/forums/images/graemlins/shiner.gif" alt="" />
'96.5 Rodeo
DOR Shackles, 1.5" Tbar Crank, Superwinch Hubs, fancy rubber floormats.
Re: The ISUZUwharrie Spring 4xFun-Run ( North Carolina ) [Re: WillV] #1094318 01/07/05 04:57 PM
Iluvmud Offline
If u can, look on independent4x.com and get some shackles and addaleaves, put those bad boys on, crank the t bars, and bang u got 3 inces of lift and u won't be banging skidpltes and it open up a few more trails with less cnahce of brakeage.
Re: The ISUZUwharrie Spring 4xFun-Run ( North Carolina ) [Re: WillV] #1094319 01/07/05 08:45 PM
Smiley Offline OP
Will - Here it is in a nutshellà
It sounds like you might possess some of the very same concerns that I had when I initially started 4-wheeling mineà
When I first went to Uwharrie, about 3-or-so-years-ago - I arrived with an almost bone stock 1997 Rodeoà The only modifications I had at that time were a set of Rancho 9000 shocks, and some stock-sized (225/75/16) Pirelli Scorpion A/Ts û No lift, no CB radio, no spare partsà nothing.
Following the group on my very first trail-run, I went from the Falls Dam trailhead -to- Slab Pile -to- Dutch John -to- Sawmill -and back out through the Falls Dam trailhead entrance. --- Along the way, I scraped the bottom of my rig on just about everything in sight!
Mind you, thatÆs not to say that I did any damage to anythingà Not in the least. --- But as a near-novice to the sport of 4-wheeling, every time that I heard my undercarriage make contact with the surface, I cringed û and IMAGINED all sorts of mangled metal horrors.
I soon learned that the underside of my Rodeo was a whole lot tougher than I thought it was.
(Anymore, I actually smile when I hear those same metal-on-rock sounds! <img src="/forums/images/graemlins/smile.gif" alt="" /> )
When I returned to Uwharrie the following spring, I had added a longer set of shackles, cranked the T-bars to match, and upgraded to a set of slightly larger tires (245/75/16s). --- For ME, this made all the difference in the world!
With just that additional 1.5-inches of suspension lift, and roughly an inch more altitude from the tires - I went from being a belly-dragger to the Trail Leader on that very same route as before. --- And the added confidence of this had me out trying some of the harder trails (the ones where I was a passenger in someone elseÆs rig on the last trip).
The returning members of this group know ALL of the trails - and more importantly, we know how to gauge whether or not someone (or their rig) is ready for the harder ones. --- If someone demonstrates a natural ability for 4-wheeling, they will be encouraged (but not forced) to push it to the next level. --- Conversely, if they should run into any difficulty, no one ever makes fun of them û instead, we offer tips and advice on how to make it through a given section (and if that doesnÆt work; youÆll find yourself on the receiving end of a tow-strap if necessary).
We take very good care of our ownà
Especially the First-Timers û because we want everyone to feel welcome to return, again and again and again.
It really is like a family (perhaps a bit of a nutty one <img src="/forums/images/graemlins/cyclops.gif" alt="" /> but a family, just the same).
And just so you knowà
All of my spare parts will also fit your 1996 Rodeoà so you wonÆt even have to worry about starting your own collection of spares - this time. <img src="/forums/images/graemlins/kewl.gif" alt="" />
Cheers! <img src="/forums/images/graemlins/cheers.gif" alt="" />
Smiley
Re: The ISUZUwharrie Spring 4xFun-Run ( North Carolina ) [Re: Smiley] #1094320 01/07/05 08:56 PM
WillV Offline
And apparently true to Smiley form, that's the biggest damn nutshell I've seen in a while. You probably could have said "get your a$$ down there and we'll take care of the rest", but hey. <img src="/forums/images/graemlins/pfft.gif" alt="" />
You guys are great <img src="/forums/images/graemlins/cheers.gif" alt="" /> and have me sold. Now for the wife. Somehow I have the feeling shackles and a TB crank won't help her 'get over it' like they will my Rodeo. <img src="/forums/images/graemlins/wink.gif" alt="" />
Lookin forward to seeing you guys in NC.
'96.5 Rodeo
Re: The ISUZUwharrie Spring 4xFun-Run ( North Carolina ) [Re: WillV] #1094321 01/07/05 09:30 PM
Smiley Offline OP
OK, so it was a 'GilliganÆs Island' mutant-radioactive coconut shell! <img src="/forums/images/graemlins/pfft.gif" alt="" />
<img src="/forums/images/graemlins/lol.gif" alt="" /> <img src="/forums/images/graemlins/lol.gif" alt="" /> <img src="/forums/images/graemlins/lol.gif" alt="" />
Does this mean that I can move you up to the actual Attendee List?
Smiley
Re: The ISUZUwharrie Spring 4xFun-Run ( North Carolina ) [Re: Smiley] #1094322 01/07/05 10:41 PM
WillV Offline
The usual host of caveats and disclaimers apply, but yes, I officially plan on making it. <img src="/forums/images/graemlins/smile.gif" alt="" />
'96.5 Rodeo
Re: The ISUZUwharrie Spring 4xFun-Run ( North Carolina ) [Re: WillV] #1094323 01/07/05 10:47 PM
Smiley Offline OP
[color:"white"][b][ Attendance List Updated ][/b][/color]
Moderated by  4x4Wire, Dandeman, Mike Bondi
PHP: 7.4.33 Page Time: 0.012s Queries: 16 (0.009s) Memory: 0.6558 MB (Peak: 0.7859 MB) Data Comp: Off Server Time: 2026-05-30 01:12:36 UTC
