Page 22 of 43 1 2 20 21 22 23 24 42 43
Re: HALLO`wharrie 2005 #1096262 09/16/05 06:42 AM
Smiley Offline OP
Zach,
DonÆt worry û there are always lots of photos!
But let me ask you somethingà
Purely hypothetically speaking û wouldnÆt having some pre-existing body damage <img src="/forums/images/graemlins/shiner.gif" alt="" /> make you all-the-more willing to go hit a few trails? --- I mean, thatÆs about 25% of the vehicle that you wouldnÆt even have to worry about, since itÆs already dinked û am I right? <img src="/forums/images/graemlins/wink.gif" alt="" />
<img src="/forums/images/graemlins/smile.gif" alt="" />
Six Isuzus, so far... still have three of them.
Re: HALLO`wharrie 2005 [Re: Smiley] #1096263 09/16/05 06:14 PM
Rodeo Guy Offline
Bad news <img src="/forums/images/graemlins/frown.gif" alt="" />
My death wobble has been diagnosed as play in the lower a-arm bushing. And my a-arms do not come off. Trust me, I used a 20 ton press on that mounting bolt and it started to bend the mount before I gave up. So it looks like my only option is to cut everything off and get a new a-arm and bolts and bushings.
That, and I need a new rear driveshaft, new wheel bearings, 2 new tie rod ends, a new steering shaft joint, new rear brake pads/rotors, rear axle seal is leaky, phhh what else am I forgetting...yep I'm 15k overdue for timing belt/water pump...
Basically, the rodeo isn't up for the trip to Uwharrie. As it is, rodeo ain't up for driving me to work right now. <img src="/forums/images/graemlins/frown.gif" alt="" />
Mike
"Damn the carnage! Full throttle ahead!"
95.5 rodeo, 37" Trxus MT, dana 44/9", coil-overs, lockers..... http://www.cardomain.com/memberpage/550454
Re: HALLO`wharrie 2005 [Re: Rodeo Guy] #1096264 09/16/05 06:17 PM
Rodeo Guy Offline
Luckily, I found a real good deal on this-
Its a 1991 Chevy K2500 with the 350. Gonna be my new daily driver/ tow rig. <img src="/forums/images/graemlins/smile.gif" alt="" /> <img src="/forums/images/graemlins/smile.gif" alt="" /> <img src="/forums/images/graemlins/smile.gif" alt="" />
Hallowharrie here we come <img src="/forums/images/graemlins/cheers.gif" alt="" />
Mike
Re: HALLO`wharrie 2005 [Re: Rodeo Guy] #1096265 09/16/05 08:49 PM
Bigpoppax2 Offline
Yeah, now someone else is getting the same crap I got. Mike, I hear ya. Been there done that. You will tear the crap out of the bushing getting it out even if you cut the a-arm off.
It took a press to get that bolt out of the bushing, and even then it came attached with the inner sleeve of the bushing. This is what I was talking about when everyone was talking about just removing your lower a-arms to send them in for the clearancing service when you buy the diff drops.
They just don't come right off. <img src="/forums/images/graemlins/shiner.gif" alt="" />
www.car-part.com a set of lower a-arms. Hope that the j-yard can get a few off for you.
Joe
Re: HALLO`wharrie 2005 [Re: Bigpoppax2] #1096266 09/17/05 08:02 AM
rubo Offline
Mikey, sounds to me like you are overdew for an SAS <img src="/forums/images/graemlins/evil.gif" alt="" />.
"If i can't crawl over it, i'll fly over it"
rubo
'96 Amigo 4x4, 3.2L V6, 4L30E, D44 rear, SOA, 1" BL, undergoing surgery.
'00 Rodeo LS 4x4, 3.2L V6, OME 919 Springs, front cranked to match,1" BL, 265/70x16 Scorion A/T's.
Re: >>> Halloween Weekend in Uwharrie! (Central North Carolina) [Re: Smiley] #1096267 09/17/05 06:57 PM
TrailMystic Offline
I reserved site #41 for me and my friend with the Rubi (assuming he can come - not confirmed).
Pete
'01 Rodeo Sport, 5 Speed Softie, Indy 4X rocker bars, OME 912's, Rancho 9000X's, Superwinch hubs, custom tube bumper with Warn 9000i , Flowmaster 50, TeraLow t-case gears, ARB front & rear lockers, TrXus MT's, Sway bar disconnects
Re: >>> Halloween Weekend in Uwharrie! (Central North Carolina) [Re: TrailMystic] #1096268 09/17/05 10:37 PM
Smiley Offline OP
I reserved site #41
<img src="/forums/images/graemlins/kewl.gif" alt="" /> (Campground Map Updated)
Re: >>> Halloween Weekend in Uwharrie! (Central North Carolina) [Re: Smiley] #1096269 09/18/05 06:19 AM
Rodeo Guy Offline
Joe, I remember reading about your a-arm trial, which is why I was so hesitant to even try to take mine off. I think I'll have to get an arm from car-parts, order new bolts and bushings from Merlin, then try and fit a sawzall blade in there to cut it off. If that doesn't work, I can always go next door and use my neighbor's plasma cutter <img src="/forums/images/graemlins/evil.gif" alt="" />
Rubo, believe me, that option has been under a lot of consideration lately. Don't have the $$$ at the moment, but we'll see. Anyone wanna buy a 5.38 geared, limited slipped, darlington dropped, front axle? <img src="/forums/images/graemlins/smile.gif" alt="" />
Mike
Re: >>> Halloween Weekend in Uwharrie! (Central North Carolina) [Re: Rodeo Guy] #1096270 09/18/05 06:20 PM
Smiley Offline OP
When-and-if it does get parted-out - I call DIBS on that 5.38 / Limited Slip front 3rd Member!
Re: >>> Halloween Weekend in Uwharrie! (Central North Carolina) [Re: Smiley] #1096271 09/19/05 05:35 AM
paulevans76 Offline
SAS time Mike <img src="/forums/images/graemlins/wink.gif" alt="" /> I'll be working on two at the same time over the next few months.
I might be able to get that weekend off, and if I can fix wheel bearing and tranny issues on the 3.4 rig I might delay the swap on it a little while and make the ride. Slim chance, but who knows.
Fall in Uwharrie is very nice <img src="/forums/images/graemlins/kewl.gif" alt="" />
88 Troop - Posing yard art
Moderated by  4x4Wire, Dandeman, Mike Bondi
PHP: 7.4.33 Page Time: 0.011s Queries: 15 (0.009s) Memory: 0.6561 MB (Peak: 0.7658 MB) Data Comp: Off Server Time: 2026-05-29 19:55:32 UTC
