4G54B N.A. valvetrain/power options and ideas #1101347 05/24/16 03:50 PM
E
ENG1N33R Offline OP
Just curious about the valvetrain power options possible within these parameters.
NON-Jet valve cylinder head
Balance shaft delete
Not with the mikuni carb- 2/4 barrell carb
Carb'd VS fuel injection
Her Name was Eileen, Because she most often was on a jack...
Re: 4G54B N.A. valvetrain/power options and ideas [Re: ENG1N33R] #1101360 05/26/16 03:56 AM
You can use a non-jet head with mechanical or hydraulic lifters.
Balance shaft delete is possible, but rattled my Max's Starion engine apart.
The 2.6L engine is rather small for most 4-bbl carbs, smallest I've ever seen or read about is about 350 cfm. Most folks that don't want the Mikuni variants use a Weber.
FI from a Starion is likely the easiest non-carb swap. But, plenty of Magna intake systems and custom pieces are available. Look up Starion boards or get on MitsuNation on FB.
Re: 4G54B N.A. valvetrain/power options and ideas [Re: ENG1N33R] #1101366 05/26/16 02:55 PM
E
ENG1N33R Offline OP
http://fitechefi.com/default.asp.pg-GoEFISystem4-InjectorKit
This is the fuel injection setup I have in mind.
I had a weber carb 36dgev on it for about a year but I took my truck off the road to get allot done on it and have the engine rebuilt by a knowledgeable shop.
Thanx for your input man!
Re: 4G54B N.A. valvetrain/power options and ideas [Re: ENG1N33R] #1101391 05/28/16 12:22 PM
Also on the Mitsubishilinks.com page there is a manual (or two) on hopping up the 2.6. Check that out
PHP: 7.4.33 Page Time: 0.011s Queries: 15 (0.009s) Memory: 0.6009 MB (Peak: 0.6576 MB) Data Comp: Off Server Time: 2026-07-17 00:09:46 UTC
