Head Bolts Replace or Not? #1101455 06/05/16 08:08 PM
P
pcc Offline OP
So I had a bit of a setback. Did not have my air pressure fully connected and dropped a valve in the cylinder doing valve seals.
I have removed the DS head to retrieve the valve. FSM does not mention replacing head bolts.
Is it necessary to install new head bolts rather than using old ones?
Thanks
Re: Head Bolts Replace or Not? [Re: pcc] #1101456 06/05/16 08:16 PM
P
pcc Offline OP
OK, I answered my own question. FSM does not say replace, Haynes says just replace in same position.
I think I'll reuse.
Re: Head Bolts Replace or Not? [Re: pcc] #1101459 06/06/16 04:15 AM
4x4Wire Offline
Easy answer... I would suggest that you run a tap through the bolt holes and clean the bolt threads with a die or wire brush.
I have a personal belief that when torque specs are involved, I want to work with clean thread connections.
John Stewart
Editor - 4x4Wire.com
Editor - 4x4Voice
Editor - MUIRNet-News
Re: Head Bolts Replace or Not? [Re: pcc] #1101461 06/06/16 05:06 AM
Also, the V6 headbolt holes are blind. It has long been advised on this board to measure the length of the bolt to be used and compare that to the sum of the hole depth plus the gasket thickness plus the head thickness. If the bolt bottoms out, then you may achieve a false torque reading.
Re: Head Bolts Replace or Not? [Re: rxinhed] #1101464 06/06/16 02:28 PM
Extremely important if'n you get new head bolts.
Re: Head Bolts Replace or Not? [Re: pcc] #1101465 06/06/16 04:18 PM
P
pcc Offline OP
Thanks all for the input. I will clean the threads and measure the length but not run a tap.
I did run a tap on the rocker arm bolts from suggestions 10 years ago but was not happy with the looseness of the fit, although they have held. I believe the head bolt threads are a much tighter tolerance fit than over-the-counter taps (75%). I am afraid of loosing too much thread surface with a tap.
Re: Head Bolts Replace or Not? [Re: pcc] #1101489 06/10/16 09:50 PM
You want a thread chaser, not a tap.
Re: Head Bolts Replace or Not? [Re: fasteddy] #1101490 06/10/16 10:24 PM
P
pcc Offline OP
Actually the bolts had little to no resistance. I was easily able to hand screw them even without oil. I have torqued them and everything went fine.
I checked length and had about 1/2" extra clearance over bolt length.
Hopefully Sunday start.
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.6223 MB (Peak: 0.7051 MB) Data Comp: Off Server Time: 2026-06-23 12:10:58 UTC
