Page 3 of 3 1 2 3
Re: Wanting BIG tires. [Re: ryany] #1101711 07/06/16 06:56 PM
ES_97Sport Offline
Originally Posted by ryany
Cryo treatment can be done on most any metal part and is a process that strengthens the metal on a molecular level. You'd have to find somewhere that does cryo treatment and take/send your disassembled parts to them.
Ian, what ryany says. Getting this done is a big deal with the IFS Toy guys and it IS supposed to help but I'd browse the Toy forums. I've run across probably (at least) a dozen companies that do this for them. I don't see why they couldn't do Mitsu CVs.
There are at least three generic cryo places within rock throwing distance of my place that would also probably do them. I think I'd stick to a reputable shop that does them for the Toy off road crowd or get a recommendation from a couple 4x4 shops for someone reputable. I don't know how much science goes into cryo treatment, but the shops around my place don't give me a warm fuzzy when I talk to them. I'm not entirely sure they REALLY know how to do what they think they're doing. smile
Re: Wanting BIG tires. [Re: TOASTY] #1101712 07/06/16 07:31 PM
ES_97Sport Offline
Originally Posted by TOASTY
You also need to consider the other side of that coin. The lower end of those torque numbers, if you have low low or say 4:1 single low you don't need to apply the power you would have with higher ratios.
You are absolutely correct! One of the things my math doesn't take into account. laugh
So without needing to bring up the RPMs to get the power to stay above a stall (or TC stall) your axles won't experience the higher torque or more importantly the shock loads from wheel spin associated with high gears.
IF you can keep the RPMs down. I have a lot more flexibility in gearing running a M/T with two different ratios in the t-case and doubler and I'm almost always running between 2500-3500 in Lo and Lo-Lo so I'm still close to peak torque. Without having wheeled an A/T with this setup, I'm just guessing that this may be different with an A/T?
Unfortunately A/T guys have to figure in the TC torque multiplication. This is kind of a 'one step forward, half a step backwards' kind of thing. smile You do cut the torque output from the engine but the TC isn't (shouldn't be) locked so there is going to be quite a bit of slip.
Now Like Edward said, if you gear for big tires and have said big tires in place you will effortlessly grenade CV's if you are not careful. for example; full lock turn, locked and bound up the slightest bump on the gas will probably result in parts flying in LOW LOW
This situation is to be avoided like the plague. Especially if you're running a solid axle with u-joints as that's where u-joints are at their weakest. One advantage CVs have over u-joints. They're stronger at angle if I remember correctly.
Re: Wanting BIG tires. [Re: MMeadows] #1101713 07/06/16 11:45 PM
We make a good team Edward!
Ian, look for shops that do a full cryo treat service. Cryo, heat treat and a micropolish, this will yield the best results. Many companies just freeze your parts and give them back to you but don't understand the science.
Re: Wanting BIG tires. [Re: TOASTY] #1101720 07/08/16 09:12 AM
Ian Sharpe Offline
OK cheers guys
97 Exceed, 3.5l SOHC auto, 4.90 gears, ARB front locker,rear Harrop E-Locker, Magnum winch, dual transfer cases also 2008 NS swb Pajero, front bar & winch
Re: Wanting BIG tires. [Re: Ian Sharpe] #1101725 07/08/16 11:10 PM
MMeadows Offline OP
Thank you everyone for the thoughtful responses and engaging conversation.
Would it be wise to change the subject of this topic to include gen ii montero and then give it a sticky?
This is really the most complete answer on the forum.
Thanks again.
97 Montero SR: 2in body lift. 33" KM2
Re: Wanting BIG tires. [Re: MMeadows] #1101762 07/13/16 05:08 AM
No. Not a lot of sticky posts. Keep the log on your home page is my method of choice.
Re: Wanting BIG tires. [Re: rxinhed] #1101768 07/14/16 03:59 AM
Just because, Montero on 40's and 2" body lift HA HA HA
Looks way better on 37's and the new wheels I got. smile
Re: Wanting BIG tires. [Re: TOASTY] #1101775 07/14/16 09:38 PM
ES_97Sport Offline
Just because, Montero on 40's and 2" body lift HA HA HA ...
That looks like Eric's Sport when we put it on 37" TSLs. lol
Page 3 of 3 1 2 3
PHP: 7.4.33 Page Time: 0.005s Queries: 15 (0.003s) Memory: 0.6353 MB (Peak: 0.7363 MB) Data Comp: Off Server Time: 2026-05-25 19:00:17 UTC
