Fresh 94SR at wreckers.. What to get?
#1101855
07/30/16 09:20 PM
Hey folks!
A 94 SR just showed up at a wreckers not too far from me and I wanted to know if anyone had any suggestions of what would be good items for use with my 89 LWB or if anyone needs a specific, small, hard to find, easy to ship part that I could grab for them.
I've currently got the following installed on my 89: -an 95 SR locking rear end (with a slight leak to diaphragm so compressor cycles when engaged). - 95SR fr. UCA's and caliper/rotor
The 94 SR at the wreckers has: -bouncy seat base -inclinometer with altimeter -sunroof -power mirrors and windows -3rd row seating -Headlight washers
Anyone have any specific needs (within reason) or ideas of parts that can be used on my 89 LWB.
Thanks!
Dave
'89 Monty LWB auto, 3rd row seating, 95SR rear + coils, genII UCA's and calipers/rotors, dual bouncies.
Re: Fresh 94SR at wreckers.. What to get?
[Re: fhuzz]
#1101862
07/31/16 10:02 PM
Dan (Oso) has used similar age torsion bars on his 89, along with all the steering components. His Monty is dreamy to drive.
Cheers
[Re: rxinhed]
#1101863
07/31/16 11:00 PM
Hey Russell, I hadn't thought of the torsion bars, thanks for that suggestion! When I go back I'll grab them, the ps pump, idler arm and the locker compressor if it's still there. Thanks! Dave Dan (Oso) has used similar age torsion bars on his 89, along with all the steering components. His Monty is dreamy to drive.
Cheers
[Re: fhuzz]
#1101874
08/03/16 11:03 AM
Another thing to check is the intake plenum for the butterflies to see if the bushings are tight.
[Re: Mudraider]
#1101878
08/05/16 03:42 PM
Hey Mudraider, didn't think of that. If I have time I will check that out although it won't benefit me(v6 3.0), but if it's good I'm assuming someone here might have a use for it down the line. Another thing to check is the intake plenum for the butterflies to see if the bushings are tight.
