Clutch getting stuck #1101891 08/11/16 05:46 PM
mfarmer10 Offline OP
Hey, I was just driving my 89' Raider V6 and the clutch pedal just got stuck to the floorboard and no longer had any tension, couldn't change the gears. I turned the truck off, pulled it back out and restarted it and it seems fine. Any idea of what this could be? I haven't any issues in quite a while but of course when I have a 4 hour drive coming up the issues start happening. definitely want to get this taken care of before hand
Re: Clutch getting stuck [Re: mfarmer10] #1101892 08/11/16 07:43 PM
cheesegrater Offline
I just went out and looked at mine and it appears that it is a hydraulically actuated clutch. I'm wondering it maybe the pivot for your pedal might be rusted or galded at the shaft.
Re: Clutch getting stuck [Re: mfarmer10] #1101895 08/13/16 04:58 PM
After (1989 to 2016), the most likely culprit will be your clutch hose swelling shut and not letting fluid pass.
Re: Clutch getting stuck [Re: mfarmer10] #1101900 08/14/16 08:16 PM
So, what did you find?
Re: Clutch getting stuck [Re: mfarmer10] #1101906 08/16/16 08:03 PM
djacidjac Offline
Mine did that. but the pedal itself would come back up. I had a leaky slave cylinder. Can you pull the pedal up with your toe and pump it a few times to get pressure? I could pump mine and then it'd work for a bit. Drove 1.5 hours home like that. Almost ran into the jeep in front of me on the trail too. I replaced the cylinders and the hose.
87 Dodge Raider 5sp 2.6l no jet valves, Tuffpan
OME Dakar leaf springs + T-bar crank + 2" body lift (4" lift).
5500lb winch, Starion alternator, grp31 marine bat'
OBA (stock AC compressor)
33x12.5x15 Baja Claws or Wintermark extra load 235/75/15 M/S
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6048 MB (Peak: 0.6696 MB) Data Comp: Off Server Time: 2026-06-22 12:48:11 UTC
