Page 2 of 14 1 2 3 4 13 14
Re: The axle Swap and Build [Re: ES_97Sport] #978963 01/07/10 12:58 AM
0778drz110 Offline
Are going to run links front and rear?
what wheelbase are you planning?
Tire size?
Springs?
Re: The axle Swap and Build [Re: Temple] #978964 01/07/10 02:51 AM
Dude, is that a baby holding that heim? Man those are stout!
Re: The axle Swap and Build [Re: Temple] #978965 01/07/10 03:03 AM
Geophie Offline
Can't wait to see your rig finished. Always liked the look of the 2door raiders.
Go ahead and at least tap some 2x4's or something into the block holes if you aren't going to flip them. You might go squishy-squishy without ye old jackstands.
1991 4dr RS, ATK 3.0, auto. Now with zero trans fats!
Re: The axle Swap and Build [Re: Geophie] #978966 01/07/10 03:12 AM
Temple Offline OP
My Fab guy an I are jacking the raider up a bit higher this weekend, so i should have the block turned for my sake and the concerned 4x4 friends i have on the forum. I'm going to use FOA 18coilover shocks with most likely a triple spring setup, but at ride height i am only trying to use 6-7" of the coilovers it come to like 65-70% droop. the rest of the travel will come during hard lines. The Johnny joints are 30degree of motion and they are 2.5" with the 1-1/4" stud. My whole thought is i'm gonna put on the good stuff, so if i ever gernade the raider i can take all this suspension work and put it under another rig at 1/4 the cost. as for axle placement i'm shooting for the from diff, to be even with the from clip. and the rear diff. should be some where under the fuel tank. ( i know what you thinking) with the lift and placement of the bump stops the rear shouldnt hit the fuel tank, if it becomes a problem then i'll either go fuel cell or custom fuel tank. I should be getting my steel tomorrow, i dont wanna ruin all the surprises but we are gonna use square stock for the four link, size 2"X2" 1/4" wall with 1.5" i.d. <img src="/forums/images/graemlins/shiner.gif" alt="" />
"No obstacle brute force and ignorance cant overcome"
89 SWB RAIDER (IN PIECES)
06 F250 SuperDuty Axles
Currently saving for F-O-A 18" Coilovers
Cummins 6bta/5r110w/np271
Re: The axle Swap and Build [Re: Temple] #978967 01/07/10 03:21 AM
0778drz110 Offline
kinda like a comp cut rear on a jeep? sweeeeett I'd do the same up front so it doesn't look funny and for extra WB
JMO <img src="/forums/images/graemlins/cheers.gif" alt="" />
Re: The axle Swap and Build [Re: 0778drz110] #978968 01/09/10 08:34 AM
Temple Offline OP
Alright did some measuring, the new wheel base will be 10'-11.5'(ft).
so im hoping that will allow it to get some gnarly angles.
Re: The axle Swap and Build [Re: Temple] #978969 01/10/10 06:30 PM
dannytuned Offline
Nice Build <img src="/forums/images/graemlins/kewl.gif" alt="" />
All that beef in the links for half ton axles? Why not one tons and 39.5's to compliment the links <img src="/forums/images/graemlins/smile.gif" alt="" />
2001Sport 3.0-Headers-Cage-RoofChop-NP231/D300-D44/ARB-Ford9/Yukon/3Link-37's+H1's-PSC Assist-108:1
Re: The axle Swap and Build [Re: dannytuned] #978970 01/10/10 07:18 PM
Temple Offline OP
well i've got two complete dana 44's and 1 ford 9" for under 400bucks so i figured its a start, then if i feel froggy i'll get a dana 60 down the road.
Re: The axle Swap and Build [Re: Temple] #978971 01/10/10 08:28 PM
0778drz110 Offline
120-138" holy jebus! I was thinking about 105ish...
Re: The axle Swap and Build [Re: 0778drz110] #978972 01/10/10 08:55 PM
Temple Offline OP
The way i meassured was with the hub at the front clip, and the rear some where middle to back of the fuel tank so as long as the four link clears the fuel tank thats where its going. I figure that should keep me from going @$$ over tea kettle.
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.005s) Memory: 0.6471 MB (Peak: 0.7551 MB) Data Comp: Off Server Time: 2026-06-21 16:19:42 UTC
