Rugged Radios vs Baofeng #1103368 05/14/17 08:43 PM
4x4Wire Offline OP
In coming weeks I will be exploring the similarities (and differences) between these two handheld radios.
Specific models are: Rugged Radios - RH-5R and Baofeng - UV-5R
On the surface, they are different color. And, initial look at specs indicates they are twins; except for cost.
First, and most important, both have the ability to transmit and receive on amateur radio assigned frequencies of 2-meter (144.000 MHz ÔÇô 146.000 MHz) and 70 cm (430.000 MHz ÔÇô 440.000 MHz). Use of these frequencies REQUIRES an amateur radio operators license.
Both transceivers are capable of full function on the common FRS/GMSR radio frequencies. This frequency range has a new series of FCC rules pending that will allow more flexibility with transmit power output level.
Both transceivers are rated at a nominal 5 watt transmitted power output. (high power - 4 watts; low power 1 watt)
The core difference, the Rugged Radios (RH-5R) comes from the factory pre-loaded with many of the frequencies used in the off-road racing/competition world. With the Baofeng, you have to search out those frequencies and program the handheld yourself.
Additional pre-loaded frequencies include seven Weather Channels and 16 GMSR Channels.
Accessories are interchangeable.
And, if you find that programming the radio manually to be tedious, there are computer assisted programs that will allow you to develop a master list of frequencies and "clone" your transceiver with that list.
I have used the product from RT-Systems for that task. While there is freeware, a connector cable is required and building your own can be hit or miss. The RT-Systems provides a ready made cable.
John Stewart
Editor - 4x4Wire.com
Editor - 4x4Voice
Editor - MUIRNet-News
Re: Rugged Radios vs Baofeng [Re: 4x4Wire] #1103456 05/15/17 09:17 PM
4x4Wire Offline OP
Update -- The Baofeng can be programmed with the frequencies set in the Rugged Radio. But, the Rugged Radios appear to be frequency limited as to programming of amateur frequencies.
Both work with GMRS -- Channels 1 - 16.
John Stewart
Editor - 4x4Voice
Moderated by  4x4Wire, Oyaji_Jon
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.005s) Memory: 0.5900 MB (Peak: 0.6395 MB) Data Comp: Off Server Time: 2026-07-09 13:32:38 UTC
