Help replacing wire harness #1103549 06/15/17 05:41 AM
MMeadows Offline OP
40 amp ign fuse pops when i turn the key
My 1997 montero sr has a short in the wire harness. I think its the wire between my neutral position saftey switch and the wire to my starter. I inspected the wireharness closely from the ignition, through the fender, and under the car where i could, but i could not find any exposed or damaged wire, so i took it to a budget (90/hr) mechanic.
from what i can tell the mechanic linked the 40 amp fuse ( the modified fuse was still in there) this melted the wire near the ignition switch ( its melted now and was not before). WHen i spoke with him picking up the car he told me he was sorry, there was melted wires, he left the covers off so i could see them, i need to replace the wire harrness in the cap and the engine bay, but he could not fix the car/ the price would not make since for the value of the car.
Has anyone ever replaced the wire harness in the cab or the engine bay? How many pieces is it in? Im going to call the dealership tomorrow to get a price quote but maybe someone has advice?
97 Montero SR: 2in body lift. 33" KM2
Re: Help replacing wire harness [Re: MMeadows] #1103552 06/15/17 06:48 PM
4x4Wire Offline
Is this what you need???
http://www.jcwhitney.com/wiring-harnesses/mitsubishi-montero-sport/c10483d50982j1s21.jcwx
It appears there may be a custom option from Painless....
http://www.painlessperformance.com/
Would be worth a phone call...
John Stewart
Editor - 4x4Wire.com
Editor - 4x4Voice
Editor - MUIRNet-News
Re: Help replacing wire harness [Re: MMeadows] #1103559 06/21/17 02:15 AM
There has been a '97 SR at You Pull It wrecking in Klamath Falls. I've been meaning to get the rear axle and locker bits. FYI
Re: Help replacing wire harness [Re: MMeadows] #1103601 07/22/17 07:07 PM
MMeadows Offline OP
Thank you everyone for your help. I got REALLY lucky with this one. Took it to an auto electric shop in town. Really nice guy found the open in my wire harness. He said it was one of the better hidden problems he had seen in his career ( i think they say that to make you feel better)
On the passenger side valve cover, there is a metal bracket that holds the harness in place. THe rubber on this bracket had warn off, and when a less the great mechanic ( or maybe myself ) tightened it back to the wire harness it made a small pinch.
he fixed the problem for $127.00
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6026 MB (Peak: 0.6594 MB) Data Comp: Off Server Time: 2026-06-03 13:15:28 UTC
