Back up light switch
#1103738
08/14/17 06:43 PM
While searching around for what was blowing my dash fuse I found that the back up light switch(?) wire had broken off and was rubbing on the drive shaft. It was just two bare wires and I can tell the switch is missing its wire connections. Any body have a part number and what is missing after being ground off by the driveshaft, will I have to make my own male connector? I tried to post a photo but would not up load. The broken switch is on the passenger side of the manual trans.
'91 montero a/t cranked t-bars 31x10.5x15 212k '90 toyota extra cab 320k v6 5 speed 31's 4x4 '99 expedition 17" alloys v-8 207k 4x4 '88 BMW 325iX 247k AWD '59 Willys Jeep Koenig PTO winch and hardtop 28k
Re: Back up light switch
[Re: graeaglecrawler]
#1103746
08/15/17 06:38 PM
Check the transmission housing close. There should be a grooved point that the connector would fasten to. I have found those types of speciality connectors at ACE Hardware and Home Depot.
PHP: 7.4.33 Page Time: 2.956s Queries: 15 (0.005s) Memory: 0.5877 MB (Peak: 0.6359 MB) Data Comp: Off Server Time: 2026-10-21 19:16:59 UTCValid HTML 5 and Valid CSS
