Montero sr sunroof swap? #1103729 08/12/17 02:44 AM
MontyEv Offline OP
Hey guys i have a 1995 Monty sr and my sunroof leaks a little and has accumulated quite a bit of rust to the point that i never use it. I just found a parts car and was wondering what the process is to swap sunroofs. I only need the sunroof glass and its frame but i feel that i will have to take the rails too. My motors fine so i wont be needing another. Thanks
1995 Montero SR. 305/70r17 1.75in bl "Mon-Terror"
Re: Montero sr sunroof swap? [Re: MontyEv] #1103735 08/14/17 12:57 AM
As long as apples are apples, drop the assembly from the parts car first. Inspect it for wear, lubricate and clean, then ready for installation. When you're ready, remove the piece from your driver, install new, button up and drive on. Maker sure to clean out all the drain pipes, too.
Re: Montero sr sunroof swap? [Re: rxinhed] #1103812 09/03/17 08:49 PM
Can likely download the FSM (factory service manual) from mitsubishilinks.com to aid you in figuring out the process. HTH!
PHP: 7.4.33 Page Time: 0.108s Queries: 15 (0.083s) Memory: 0.5913 MB (Peak: 0.6450 MB) Data Comp: Off Server Time: 2026-10-25 04:13:07 UTC
