Rating: 1
Page 34 of 52 1 2 32 33 34 35 36 51 52
Re: suzi the psychic [Re: rascott] #1103814 09/04/17 03:16 PM
rascott Offline OP
o k.
tried figuring out the pic thing, but haven't yet.
heard of photoshop complaints, and now may understand why....i see those pics are locked or something....
set suzi free on the road- lots of drivetrain noise that gets louder w/speed.
hmmm.
it will be howling on the hwy.
i worry about the hwy stuff.
'94 "tracker", with some parts from suzi the psychic.
other modifications made, with more to come.
some intentional.
suzitoo should get me fishing.
kj6esv
Re: suzi the psychic [Re: rascott] #1103817 09/06/17 03:43 AM
rascott Offline OP
trying a pic
....hmmm. a bit better- at least on my end- but not much
some intentional.
kj6esv
Re: suzi the psychic [Re: rascott] #1103875 10/01/17 08:24 PM
I've had a general conversion to Imgur for pics, recently. There's no similar third-party image as Photobucket has been giving recently. Cheers
Re: suzi the psychic [Re: rxinhed] #1103902 10/07/17 07:16 PM
rascott Offline OP
old dog/new trick.
we will see about pics.
i did torture suzi w/some hyway howling, and made a fishrun w/miss bitchy.
i had peeked into her differential, expecting to find mush bearings, but it looked fine.
i reset the bearing preloads and backlash and stuffed it back in.
no change.
i have successfully removed an axle bearing from the left axle, and should be able to do the right side- expect to have her back in operation next week.
mabe new outer bearings will quieten her down......?
miss bitchy did real well. we had some snow on our way in. got interesting.
some intentional.
kj6esv
Re: suzi the psychic [Re: rascott] #1103905 10/10/17 12:09 AM
rascott Offline OP
success in replacing the axle bearings(and outer seals).
had to make an interesting jumble of items to act as a press plate, to remove the bearings- installation was more conventional.
something in the gearbox(?) is still howling, louder w/speed.
everything seems to work fine.
with ear plugs.
i had replace the transmission/transfercase mounts(and engine mounts) with some very solid "unbreakable" ones.
the stock things kept ripping the rubber apart.
perhaps i am just hearing more gear noise due to lack of isolation......?
perhaps another run in a couple weeks.
i took some pictures of the bearing work. it was interesting. i should learn how to post 'em.
some intentional.
kj6esv
Re: suzi the psychic [Re: rascott] #1103951 10/29/17 04:40 PM
rascott Offline OP
haha.
nixed the fishrun idea, and decided to strengthen the chassis- where the steeringbox bolts on.
several cracks and tears have been appearing, as if the chassis has been twisting.
got some metal plates and straps formed, and intend to weld it all together.
this could even look good.
some intentional.
kj6esv
Re: suzi the psychic [Re: rascott] #1103960 11/06/17 02:59 AM
rascott Offline OP
-it certainly looks like something happened to it, and it kinda looks like i thought it should........
metalglued the plates and straps to the chassis.
expect to see if the steeringbox will still fit sometime this week.
squirted some paint to hide the repair site.
some intentional.
kj6esv
Re: suzi the psychic [Re: rascott] #1103992 11/26/17 04:49 AM
rascott Offline OP
the steering box fits- still need to weld a steering limiter in place, and remount the pump&hoses&reservoir- should work.
got sidetracked by flailing around w/the grinder, damaging the copper tubing for my old mechanical oil pressure guage.
wiring an upgrade triggered a revisiting of the rats nest of splicing....added some nest.
i will be surprised if suzi's soft top lasts another year. her back "window" has been a problem(zipper) pretty much since it was new.
gotta think of a hardtop. mabe.
some intentional.
kj6esv
Re: suzi the psychic [Re: rascott] #1103993 11/26/17 10:29 PM
just watch suzi on the 'con
nice to see you're still working with her
Re: suzi the psychic [Re: rxinhed] #1104000 12/01/17 11:47 PM
rascott Offline OP
haha
suzi could see the 'con again- still looking like this steering breakage repair will work.
finished w/the metal glue gun(mabe) by sticking on a steering stop, so i can make her mobile again.
still gotta fixup some of her electric "circuit".
some intentional.
kj6esv
Moderated by  4x4Wire, code33
PHP: 7.4.33 Page Time: 0.017s Queries: 17 (0.014s) Memory: 0.6548 MB (Peak: 0.7956 MB) Data Comp: Off Server Time: 2026-07-13 02:01:37 UTC
