Body mounts #1103983 11/16/17 12:32 AM
Montero84 Offline OP
Hello, everyone.
Does any one have experience replacing the body mounts on a Montero Gen1? I know many have installed lift kits, but that would involve disconnecting many things from the vehicle. I am wondering if replacing the body mounts would also involve disconnecting the fuel tank, radiator hoses, etc or if it just a matter of unbolting the body mounts, lift the body a little bit and replace the body mounts.
Thanks in advance.
Re: Body mounts [Re: Montero84] #1103985 11/16/17 05:15 AM
You should be able to wiggle the OE mounts out, so long as the metal sleeve within cooperates.
Re: Body mounts [Re: Montero84] #1103997 11/29/17 05:42 AM
djacidjac Offline
I'm pretty sure you could jack up each side of the body just enough to make it easier without disconnecting anything. Follow the method in the body-lift how-to: remove all the nuts, jack up one side with a 4x4 post along the rocker panel pinch seem and swap out al the mounts on that side. then switch to the other side. In your case only jack as necessary. I'm guessing no more than a half an inch.
87 Dodge Raider 5sp 2.6l no jet valves, Tuffpan
OME Dakar leaf springs + T-bar crank + 2" body lift (4" lift).
5500lb winch, Starion alternator, grp31 marine bat'
OBA (stock AC compressor)
33x12.5x15 Baja Claws or Wintermark extra load 235/75/15 M/S
PHP: 7.4.33 Page Time: 2.534s Queries: 15 (0.009s) Memory: 0.5928 MB (Peak: 0.6464 MB) Data Comp: Off Server Time: 2026-07-15 04:15:26 UTC
