Carb Question #1104054 01/07/18 11:16 PM
8
87Raider Offline OP
Hello, I'm thinking of putting a header on my 87 2.6l., will the carb jetting be okay with it or will it run lean? Also i'll be removing the CAT. Thank you for any info
Re: Carb Question [Re: 87Raider] #1104059 01/10/18 08:38 PM
You will want to jet up
There is actual Mitsubishi advice in the Colt Rallye manual, available for download at Mitsubishilinks.com
Re: Carb Question [Re: rxinhed] #1104076 01/14/18 12:17 AM
8
87Raider Offline OP
Thanks, it looks like that's for the side draft carbs. do you have any idea where I could buy an up jet for this carb?
Re: Carb Question [Re: 87Raider] #1104080 01/16/18 12:38 AM
Noah Zimmerman or Mike Warme
Re: Carb Question [Re: rxinhed] #1104092 01/20/18 04:06 AM
8
87Raider Offline OP
Re: Carb Question [Re: 87Raider] #1104096 01/21/18 12:15 AM
I've not followed these links, yet. Have you found a jet solution?
Re: Carb Question [Re: rxinhed] #1104107 01/21/18 02:27 AM
8
87Raider Offline OP
Well the guy at guaranteed carburetors said the computer would adjust itself for the header, but I'm not sure how it would do that. So I went with the Weber setup from Recarb out of Australia with a new fuel pump as well.
Re: Carb Question [Re: 87Raider] #1104116 01/21/18 06:06 PM
The feedback carb system is very basic compared to newer FI systems.
With a Weber, the header solution is solved. You have no emission testing in the home area? If you, put a turbo muffler behind the header sans cat and have that much more flow.
Also, there are lots of tech articles about the Weber conversion on this site, you'll just have to scare them up with the Search.
Re: Carb Question [Re: 87Raider] #1104213 02/24/18 04:46 AM
8
87Raider Offline OP
Here's a couple of pic's of the header and Weber, KN Apollo cold air intake in the works.....
Re: Carb Question [Re: 87Raider] #1104222 03/02/18 03:44 AM
Pretty, pretty
PHP: 7.4.33 Page Time: 0.007s Queries: 16 (0.004s) Memory: 0.6322 MB (Peak: 0.7402 MB) Data Comp: Off Server Time: 2026-06-12 11:51:10 UTC
