ECU code reading - first timer rookie #1104093 01/20/18 08:19 AM
jeffmort Offline OP
I have a new to me 1991 Montero LS 4-door. I have only owned 1970 and older "fun" cars before this car so I am not familiar with fuel injection systems, ECU's etc.
I am having a problem with my car cutting out/dying at random times so I am trying to diagnose the problem by making my first attempt at checking the ECU for an error code using my voltmeter,
I have read through the OEM service manual as well as good threads on this site so I think I am on the right track to make my first ECU check/diagnosis.
I have located my self diagnosis connector (underneath my glove box). When compared to the picture/diagram in the service manual, the connector on my car appears to be installed "upside down" relative to the diagram shown in the manual, which is fine, I just want to make sure that I am connecting my positive and negative voltmeter wires to the correct spots on the ECU connector.
Attached is a picture of how I believe my voltmeter should be connected - did I connect it correctly?
I will follow up with my diagnosis results to let you know what I came up with...and probably ask more questions.
Thanks.
Jeff
Jeff
1991 Montero
Re: ECU code reading - first timer rookie [Re: jeffmort] #1104102 01/21/18 12:33 AM
Connectors usually are 1 way position, but...?
PHP: 7.4.33 Page Time: 0.006s Queries: 16 (0.004s) Memory: 0.5857 MB (Peak: 0.6507 MB) Data Comp: Off Server Time: 2026-06-11 15:37:07 UTC
