correct idle RPM for 91 Montero
#1104094
01/20/18 05:32 PM
When operating correctly and the engine warmed up, what should the idle RPM be? Truck is a 1991 Montero 3.0. Thanks.
Jeff 1991 Montero
Re: correct idle RPM for 91 Montero
[Re: jeffmort]
#1104095
01/21/18 12:12 AM
According to the FSM. Page 14-55:
Curb idle speed is 700 +/- 100 rpm
[Re: jeffmort]
#1104104
01/21/18 12:35 AM
Thank you. Is adjusting the throttle body screw or to lower the idle a proper fix or is that a band aid approach?
Jeff 1991 Montero
[Re: jeffmort]
#1104106
01/21/18 12:38 AM
Everything has to be adjustable, right? Otherwise, no adjustment screw?
I'd adjust there and see what results. Adjustment screws can normally be reset (or set back) easily.
[Re: jeffmort]
#1104110
01/21/18 03:32 AM
adjusted - all is good now - thank you.
Jeff 1991 Montero
[Re: jeffmort]
#1104115
01/21/18 06:02 PM
PHP: 7.4.33 Page Time: 0.017s Queries: 15 (0.013s) Memory: 0.6091 MB (Peak: 0.6786 MB) Data Comp: Off Server Time: 2026-11-12 15:51:03 UTCValid HTML 5 and Valid CSS
