1989 LWB Check Engine Light #22 Crank Angle Sensor #1104347 05/19/18 03:57 AM
chadzeilenga Offline OP
Hi All,
Shortly after I replaced the failed AC Temp Sensor, I got a new Check Engine Light. I was able to read the code to be 2 long sweeps and then 2 short ones which I believe is a #22 (Crank Angle Sensor)
What I have been observing is that when cold, the vehicle has been hard to start. It will crank over strong, but I seem to feather the gas a little to get the RPM's up as it sputters etc and then is fine the rest of the time I am driving it. Warm re-starts are not a problem. Only other issue is a slight miss/rough idle in gear only, not yet sure if they are related.
So I read through the MPI manual. For a cold engine, it mentions the fast-idling air valve, but I cannot seem to find this anywhere else in the manual. Section from manual is attached.
Re: 1989 LWB Check Engine Light #22 Crank Angle Sensor [Re: chadzeilenga] #1104348 05/19/18 02:09 PM
dfreem01 Offline
It's referring to the Idle Air Control Valve. IAC. It's on the air intake. David
Re: 1989 LWB Check Engine Light #22 Crank Angle Sensor [Re: dfreem01] #1104349 05/20/18 04:34 AM
Hi David,
Thanks for that. I pulled it out tonight and cleaned it all up. I really need to pull the throttle body, but will wait for the gasket I ordered to come in the mail.
IACV Dirty
IACV Cleaned
PHP: 7.4.33 Page Time: 0.007s Queries: 17 (0.005s) Memory: 0.5933 MB (Peak: 0.6620 MB) Data Comp: Off Server Time: 2026-06-18 07:15:50 UTC
