Lock Engine to Pull Crank Bolt #1104581 09/27/18 08:16 PM
KWitcher Offline OP
I have a wobbly crank pulley. When I tried to turn the bolt to remove it, the bolt was somewhat loose. I got the bolt about half way out but must be hitting a bad spot on the threads because it got tight and now I am turning the engine. How can I lock the engine so that I can remove the difficult bolt?
The other methods in here talk about locking the pulley. That doesn't help me because engine turns w/o the pulley. Surely there is a way to block the engine or transmission for the removal of the bolt. I may need the same method for torquing since I dont know where to find that special tool to lock the crank pulley.
Any help really appreciated.
Ken
95 Montero SR
Re: Lock Engine to Pull Crank Bolt [Re: KWitcher] #1104583 09/29/18 03:24 AM
Try removing the transmission bellhousing inspection cover and block the ring gear. Fill the pistons with air using a manifold and air through the spark plug holes...this is not a serious suggestion. Can't think of any other methods, short of air tools.
Re: Lock Engine to Pull Crank Bolt [Re: rxinhed] #1104584 10/03/18 07:54 PM
Oso Offline
i use a chain wrench on the pulley to stop everything from moving. be sure to use a section of old fan belt in the groove to avoid damage.
Re: Lock Engine to Pull Crank Bolt [Re: KWitcher] #1104585 10/04/18 01:20 AM
MarkG Offline
Would an impact wrench (air or electric) work? Maybe it could back the bolt out without causing the crank and pistons to rotate.
Re: Lock Engine to Pull Crank Bolt [Re: KWitcher] #1104629 10/21/18 09:48 PM
JAVYPRO Offline
I had to lock it from the can gear using a rope.
Javy
88 red Montero with the Dakar Special Edition decals, 438,000 miles (As of 7/23/2012) some occational blue puffing but still strong and counting!!! I am going ppsshhh (turbo), Stay tuned =) ...
PHP: 7.4.33 Page Time: 0.011s Queries: 16 (0.009s) Memory: 0.6068 MB (Peak: 0.6716 MB) Data Comp: Off Server Time: 2026-07-17 01:57:17 UTC
