Page 5 of 6 1 2 3 4 5 6
Re: Introduction & New Raider [Re: Bigshankhank] #1104887 03/03/19 07:15 PM
Bigshankhank Offline OP
Speaking of, once I hit 200,000 miles the maintenance light came on, and I cannot find anything here on how to reset it. Is it just a matter of pulling the + lead off of the battery and allowing the ECU to reset? If not, how can I reset this?
1989 Dodge Raider V6
2001 Jeep Wrangler 4.0L
2008 Toyota 4-Runner SR5 4wd
Re: Introduction & New Raider [Re: Bigshankhank] #1104896 03/04/19 11:55 AM
cheesegrater Offline
https://mitsubishiforum.com/forum/general-mitsubishi-chat-5/how-reset-"service-required"-light-26541/
Re: Introduction & New Raider [Re: Bigshankhank] #1104897 03/04/19 05:48 PM
I figured it had to be a mechanical switch somewhere, that's awesome thank you!
Re: Introduction & New Raider [Re: Bigshankhank] #1105001 05/09/19 08:40 PM
Finally decided to stop risking my life on the highway and replaced the old Primewells for something just a shade better, and definitely newer.
Re: Introduction & New Raider [Re: Bigshankhank] #1105004 05/11/19 02:20 AM
Tuxedo_Ranch Offline
New tires look good, what size are they? I hope mine looks good with it's new tires, just gotta get it out of the shop. Having a difficult time being patient.
87 GEN1 Raider 5-spd w/ Weber (HAGAR)
87 GEN1 Monty 5-spd stock (LUCKY EDDIE)
88 GEN1 Raider A/T w/ Weber (HELGA)
87 Ford Ranger STX 5-spd 2.9L V6
95 Ford Bronco Eddy Bauer
99 Toyota 4-Runner Limited 3" lift
WELCOME TO MY "USED" CAR LOT
Re: Introduction & New Raider [Re: Bigshankhank] #1105008 05/11/19 11:53 AM
31x10.50x15, they are not OEM size but its what the PO had on it when I got it. The spare is the correct size but its also on an OEM rim, I debated pulling a set of original rims of a junkyard Raider I found locally just so everything matched but the Toyota rims that are on mine are wider, and frankly I was too lazy to lug a jack out to the back of the junkyard to get the other ones lol.
Re: Introduction & New Raider [Re: Bigshankhank] #1105011 05/12/19 12:36 PM
I bought some new Pro Comp 69 series wheels a couple months ago for $67 each (w/ free shipping) at "4wheelparts.com". They are flat black which will match the motif I'm going for on my Raider.
Read your PM about the wiper arm and give me your address so I can get it shipped out to you.
Re: Introduction & New Raider [Re: Bigshankhank] #1105031 05/27/19 02:24 PM
Well rehabbing the brakes has turned in to a nightmare. ItÔÇÖs obviously been quite some time since they were serviced, and yes I am ashamed for putting it off so long but despite a tug to the left when pressed hard, they werenÔÇÖt making any noise and they were technically still stopping the vehicle. But I started hearing a squeak so I figured it was finally time to dig in, I bought new shoes, hardware and cylinders for the rears, and new pads and bleeders for the front, plus tons of spray cleaner and new DOT3.
I never got past the rears, in fact as of writing this I am three days in and still not done with them. Several of the springs and one shoe retainer pin were on the verge of failure due to rust, plus I had to drill out a lug because it broke loose and was spinning. Then once I finally got everything cleaned up, reassembled (IÔÇÖll still have to take it to a shop to press in a replacement lug) and I started bleeding everything one of the hard lines broke and sprayed fluid all over my rear diff. I bought a replacement line and was about to start bending it in to shape but then decided IÔÇÖd had enough last night and just hopped in my pool. Gotta finish at least the rears today, and save the fronts for next weekend.
Re: Introduction & New Raider [Re: Bigshankhank] #1105032 05/27/19 03:28 PM
You don't need a press for a lug, just use a stock steel type lug nut and thread the lug tight. Make sure to use the flat of the nut and some light grease to prevent galling.
The brake line you purchased is metric, yes? Don't forget to clean and repaint wherever brake fluid sprayed.
Are you also replacing the several brake hoses in this refresh?
Re: Introduction & New Raider [Re: Bigshankhank] #1105034 05/28/19 12:23 AM
ThatÔÇÖs a good point, any chance you know a good source for stainless lines?
PHP: 7.4.33 Page Time: 0.008s Queries: 16 (0.005s) Memory: 0.6421 MB (Peak: 0.7674 MB) Data Comp: Off Server Time: 2026-06-07 07:05:44 UTC
