Rating: 1
Page 39 of 52 1 2 37 38 39 40 41 51 52
Re: suzi the psychic [Re: rxinhed] #1104876 02/24/19 03:45 AM
rascott Offline OP
hey russell-we think alike.
the rest of her old tube was fine, but the drain plug was becoming difficult- so much of it was ground away!
i made up some sacrificial skin to thicken the bottom.....
and stiched it on.
after i flail around at it with a grinder for awhile, i'll add another smaller layer - bring it up to grade.
interested in how these larger rear brakes could work. everything always felt kinda weak back there.
'94 "tracker", with some parts from suzi the psychic.
other modifications made, with more to come.
some intentional.
suzitoo should get me fishing.
kj6esv
Re: suzi the psychic [Re: rascott] #1104878 02/25/19 06:10 AM
rascott Offline OP
got some more done.
the tube, with differential, is back in place.
some intentional.
kj6esv
Re: suzi the psychic [Re: rascott] #1104886 03/03/19 06:20 AM
rascott Offline OP
weather has conflicted w/suzitime, but the axle is complete.
in little bits, the brake plumbing and cables are going together, and i have decided to replace the front brake hoses.
30yrs. could be pushing it, and caps510 showed us what losing a front brakehose can be like- on the last sierra carnage run!
anyway- mabe suzi the psychic will take me to work next week. testrun.
i can smell the season, and want to be ready.
looking forward.
some intentional.
kj6esv
Re: suzi the psychic [Re: rascott] #1104894 03/04/19 02:21 AM
rascott Offline OP
kinda wet, but i was seeing the possibility....
finished the plumbing and bled out all the old brake fluid, and put her shoes back on.
bent the stock brake lines to run higher across the tube- used to be right across the back. mabe a bit less exposed.
gonna street her in the am- see if i tightened everything.
some intentional.
kj6esv
Re: suzi the psychic [Re: rascott] #1104904 03/09/19 11:16 PM
looking good
Re: suzi the psychic [Re: rascott] #1104940 04/07/19 11:02 PM
rascott Offline OP
this always makes me smile. mabe i posted it before.....
i have metalglued something to hold the trans/transfer boxes in place.
suzi and miss bitchy are discussing a run.
l8tr040719
bolted up o k.
some intentional.
kj6esv
Re: suzi the psychic [Re: rascott] #1104967 04/17/19 03:27 AM
rascott Offline OP
been having only bits of time recently, but suzi gets tickled when possible.
a couple of years ago she suffered some of fordyce, and destroyed one of the right side bodymounts.
the left side showed signs of similar failure, but i only fixed the "broken" one.
mabe i can make a neater repair this time.
i should take som pics... mabe this weekend.
some intentional.
kj6esv
Re: suzi the psychic [Re: rascott] #1104969 04/18/19 03:53 AM
Tuxedo_Ranch Offline
ThatÔÇÖs one serious looking heavy duty cross member. I like it
87 GEN1 Raider 5-spd w/ Weber (HAGAR)
87 GEN1 Monty 5-spd stock (LUCKY EDDIE)
88 GEN1 Raider A/T w/ Weber (HELGA)
87 Ford Ranger STX 5-spd 2.9L V6
95 Ford Bronco Eddy Bauer
99 Toyota 4-Runner Limited 3" lift
WELCOME TO MY "USED" CAR LOT
Re: suzi the psychic [Re: Tuxedo_Ranch] #1104972 04/18/19 08:25 AM
rascott Offline OP
i hope it will take abuse better than the stock xmember, and help align the driveline better- still have to adapt the skidplate(s) to the new arrangement, but it'll happen.
this is the left bodymount(under drivers feet) that finished tearing off last season.
gonna metalglue some stiffener/mount stuff in there....
hmmml8tr
kinda crappy picture. i'll try again before i hack it up.
some intentional.
kj6esv
Re: suzi the psychic [Re: rascott] #1104974 04/19/19 02:56 AM
OUCH! Looks like Suzi has a booboo. She must be a pretty tough girl'. We don't have much for rocks to crawl around on here in Kansas. Can be had in any direction but north, but it takes a minimum of 5 hrs. I'm interested in seeing how you do the repair so keep up the pictures (please).
Moderated by  4x4Wire, code33
PHP: 7.4.33 Page Time: 0.020s Queries: 16 (0.017s) Memory: 0.6565 MB (Peak: 0.7831 MB) Data Comp: Off Server Time: 2026-07-16 02:44:37 UTC
