89 v6 Reluctant To Start After Rain/Snow #1105209 09/04/19 02:46 AM
P
polar Offline OP
If it rains or snows and I don't run it that day the car is a bear to start the next day. No problem starting on dry days or cold days.
I've replaced fuel sender, fuel lines, distributor cap/rotor
I'm thinking to replace the ignition coil next....or maybe the ignition relay switch??
What do the Sages say??
Re: 89 v6 Reluctant To Start After Rain/Snow [Re: polar] #1105210 09/04/19 11:20 AM
cheesegrater Offline
Did you replace the spark plug wires?
Re: 89 v6 Reluctant To Start After Rain/Snow [Re: polar] #1105213 09/04/19 11:06 PM
P
polar Offline OP
Hey Cheesy
Yep ...but this has been a Long (like forever) on going problem....not sure how long ago I put new plug wires in.....less than 7 years for sure....but didnt seem to make any difference that I recall
Re: 89 v6 Reluctant To Start After Rain/Snow [Re: polar] #1105214 09/05/19 02:20 AM
MarkG Offline
I had that problem on my 89 V6. There is an o-ring that sits between the distributor cap and the distributor body. There were only fragments of the original when I purchased the truck. The o-ring part number is MD611460. I opened up all the electrical connections and sprayed some contact cleaner/lubricant on the contacts. Once both of these were done, the hard starting in damp weather went away.
Re: 89 v6 Reluctant To Start After Rain/Snow [Re: polar] #1105219 09/05/19 09:48 PM
P
polar Offline OP
Hey Mark,
Thanks for the reply!
I had recently heard of that being a solution and when I replaced the Distributor cap/rotar....(just last week) I checked that O-ring and being that I bought and installed a new distributor just 8 years ago my o-ring looked to be in great shape.
I did clean off oxidation on the distributor body and greased the O-ring and where the distributor sits on the o-ring with dialectical battery grease.
....but that did Not solve my problem in any way...Ugh!!
When and Where did you buy a New OEM O-ring?? Also, you got a caliper to measure what thickness your O-ring is? I would like to compare to mine to see if there's a difference.
What were "all the electrical connections" that you cleaned and lubed and what cleaner/lube did you use??
Re: 89 v6 Reluctant To Start After Rain/Snow [Re: polar] #1105220 09/05/19 11:04 PM
chadzeilenga Offline
I ended up measuring my distributor and bought an o-ring sized for that ID off of Amazon. M2.5x90 Viton
Re: 89 v6 Reluctant To Start After Rain/Snow [Re: polar] #1105221 09/06/19 01:15 AM
P
polar Offline OP
Chad - is this the one you got off Amazon?? -40 to 212f temp range
https://www.amazon.com/M2-5x90-Buna...567732121&s=gateway&sr=8-1-fkmr0
Re: 89 v6 Reluctant To Start After Rain/Snow [Re: polar] #1105222 09/06/19 02:14 AM
I donÔÇÖt think you want the buna material, lower temp resistance.
M2.5x90 Viton O-Ring, 75A Durometer, Round, Black, Viton, 90 mm ID, 95 mm OD, 2.5 mm Width (Pack of 5) https://www.amazon.com/dp/B00NJPP6KM/ref=cm_sw_r_cp_apip_Oc64WrB65mR2Q
Re: 89 v6 Reluctant To Start After Rain/Snow [Re: polar] #1105224 09/06/19 11:35 AM
P
polar Offline OP
Good to know! Too bad it's not available!
Re: 89 v6 Reluctant To Start After Rain/Snow [Re: polar] #1105226 09/08/19 02:11 PM
P
polar Offline OP
PHP: 7.4.33 Page Time: 0.009s Queries: 16 (0.006s) Memory: 0.6329 MB (Peak: 0.7562 MB) Data Comp: Off Server Time: 2026-10-29 06:40:12 UTC
